Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
It shows this device can perform faster. the pen drive is slow
When i connect my pendrive it shows this device can perform faster. and the pen drive is also working slow
  • 101 Answers
When it says this devices could work faster your pc is referring the the speed of your usb ports. There is usb 1.0 (standard speed usb )
and usb 2.0 (hi speed usb) The speed of your usb port is determined by your motherboard. I get this message on my pc every time I plug in a usb device, even though I only have usb 1.0 a bit annoying but not a problem. My mac has usb 2.0 ports and it takes about a quater of the time to transfer data.
THeres not too much you can do if you think your pen drive is running slow, apart from making sure your pc has lots of free hard drive space and ram (usefull for data transfer) and at somepoint backing up your data and formatting your usb pen.
Posted on Jul 24, 2009
  • rohanaswal Nov 03, 2010
    any sugesstion if i could solve it through registery
    President:
  • 627 Answers
This is usb issue
your computer usb has a lower version than your pendrive
you cannot use better drivers because this is from mainboard chipset
Also you can put a pci usb card version 2.0 for your pendrive
HPv165w recognized in Device manager...But cant open it in My computer..
Try inserting the pen drive into another computer to see if you can open the data on this pen drive.
If not you may need to format the pen drive.
Nov 24, 2012 | Electronics - Others
Very slow transfer to Kingston 8GB datatraveler
HI,
- Check if your PC is running at its maximum efficiency
- Close all side processes that are not of any use to you. This can be done by pressing :Ctrl+Shift+Esc and then going to processes. In there only close the processes that are under your user name and are of no use. NOTE: DON'T CLOSE "EXPLORER.EXE". This will free a sizeable amount of your RAM, making your PC generally faster.
- While copying anything, avoid multi-tasking as that will simply slow down your PC, causing a delay in the copying.
IF NONE OF THIS WORKS, then create a back-up of all the software in your Pen-Drive and then format it.
This should just about do it.
If still the problem persists, go to your dealer- your pen-drive must be in its warranty period.
Sep 30, 2008 | Electronics - Others
My pen 4gb pendrive is working very slow it works 800kbps
When you plug in your USB pendrive into your computer and you get a message "This device can perform faster if connected to a high speed USB2 port".
This means your computer supports USB1 which is much slower than USB2 and the latest USB3.
There may be a BIOS upgrade to configure your computer to support USB2.
May 26, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pendrive's copying speed is very slow. its capacty is 8 GB. whn i connect pen drive to the PC its get lots time rather then normal time. and when i copying some data its gets slow.
format the pen drive after taking the backup and then defragmented it you will get smooth work in your pen drive. If not so fast after defragmentation then check your computer configuration and its space may be it is due to your computer is slow you con check whether your pen drive is ok or not by connecting it to any other good pc. good luck
And please vote me and rate me..
Jan 04, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
This device can perform faster ??
Go to device divers and make sure you have the right driver installed...some other download you may have done might have changed the original driver..try to download new driver from original sight
Oct 02, 2009 | Kingston Technologies 512MB DataTraveler I...
My pendrive performancce is very low.when insert the pendrive ...the divice can perform faster option is coming.but it's performance is slow.(copy and delete)
What is the specification of your computer?
Also, try formatting the pen drive and then use it.
This issue may come when you have virus on the system or the pen driver.
Aug 04, 2009 | Computers & Internet
Transcend 2GB Jet Flash V30 problem
There are some specification of USB speed. There are usb 1.0 , 1.1 , 2.0 . 2.0 is fastest among these. Normally back panel USB ports are USE 2.0 s. If you have installed your motherboard successfully , they should be working fine. Please try Installing those. If it not works, probalby your motherboard has not hte capablity of running usb 2.0 s.
thanks
Apr 18, 2009 | Computers & Internet
Dear sir, I am having Transcend 2 GB pendrive but when I insert it in my computer, it gives message THIS DEVICE CAN PERFORM FASTER IF U CONNNECT IT TO HIGH SPEED USB 2.0 PORT and its speed is also ver
If you have a USB port on the back of computer plug it in there. Or use USB extension if it is uneasy for you to plug your pen drive from time to time. From there you can hook up your pen drive much easy.
Apr 13, 2009 | Computers & Internet
When pendrive is connected shows device has malfunctioned
when i connedted my pen drive i show has malfunctioned
Dec 14, 2008 | Transcend (589307) Media
Pendrive i/o device error. it can,t formatte or write send solutions
tell ur pen drive model.
as some pen drives has option to lock it (manually). check it out.
Oct 13, 2008 | Electronics - Others
Electronics - Others Logo
734 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
