Question about Dell 1600n All-In-One Laser Printer
Mac user can't scan on Dell MFP 1600n
I am a mac user and have a Dell laser MFP 1600n. I'm using an airport extreme wireless set up to print and have no problems printing. I can't get it to scan..... I haven't loaded any software. Can you help?
Thanks,
kg
    Problem Solver:
  • 8 Answers
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
Posted on Aug 03, 2009
5 Suggested Answers
SOURCE: Driver for mac OS for Dell 1600n
the Dell 1600n is indeed a re-branded Xerox PE120. I did a search on that model and "OS X" and found the appropriate driver on the Xerox website. Loaded it and it works like a charm.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=PE120_PE120I&Xlang=en_US&Xcntry=USA
Posted on May 08, 2008
SOURCE: Does HP laserjet 1020 work with Airport Express
I removed any printer configurations for this printer in both my pc and my mac (both usb and wireless). Then I restarted both computers and added the printer via usb again to each. At that point I went back to the extreme configuration and under the printers tab it was finally seeing Hewlett Packard Laserjet 1020. After that, adding via Bonjour went smoothly on both platforms.
Posted on Oct 18, 2008
SOURCE: Scan function won't work with Mac OS10.5.5 & Airport
I have a new macbook pro OS 10.5 and installed a new HP L7590 all in one printer. Same problem. Called Apple and they confirmed that they do not have a driver for the Airport Express to allow scanning wireless. Therefore, SOL. If want to scan, then have to unplug from APE and plug into laptop. My solution is to use a USB hub and mount close to desktop so I can easily remove my HP and connect to laptop to scan often (or buy a cheap flatbed). GARY
Posted on Jan 16, 2009
SOURCE: dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Posted on Jul 20, 2009
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Can the wireless option on the airport extreme be turned off from the outside? I did not set a password.
Hi Friend
If you are using a Mac laptop then yes there is a way. on your MAC laptop there is a wireless switch to turn off and on the airport. You can use that to turn off the airport from outside.
warm regards
Chiranjeet Mitra
Oct 08, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Airport Extreme Bases Station not detectable with utility
This depends... Reaching them wirelessly may be unreliable for a number of reasons, so, I'll proceed on the assumption that you are attempting to test in the simplest lowest-variable situation:
First, make sure that you have the latest Airport Utility for your Mac.
Connect your Mac to the Airport via a single Category 5 (or 5e or 6) cable. Factory-reset the Airpot and then wake up the Mac. If the utility still can't discover your airport, it's probably time for a trip to your local Genius bar as you most likely have a hardware problem.
Lather, rinse, repeat for each of the two airports.
Apr 28, 2009 | Apple AirPort Extreme Base Station...
Reply: What wireless card does your macbook have?
AirPort Card Information:
Wireless Card Type: AirPort Extreme (0x168C, 0x86)
Wireless Card Locale: USA
Wireless Card Firmware Version: 1.4.8.0
this info can be found in apple/about this mac/more info/system profile/airport card
Jan 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I tried to set up HP Photosmart C4580 printer/scanner/copier with my Airport Extreme. However it is not connecting to the Airport Extreme. Diagnostic check recommends temporariiy disabling the Mac Address...
MAC address filtering is used to prevent unauthorised people getting access to your wireless network. you need to get into the Airport Extreme configuration using Internet Explorer or any other browser, then select wireless setup then MAC address filtering. You need to turn off MAC address filtering.
Check your manual on how to configure your Airport Extreme.
Dec 02, 2008 | HP Office Equipment & Supplies
1600n Printing an Extra Page everytime...
I had a computer experiencing the same problem.
I found under the printer properties that there was 2 drivers listed; both say "Dell Laser MFP 1600n PCL 6"
I swtiched the settings from one to the other.
The Printing Preferences also show more options.
  • Open the Printer(Control Panel->Printers>Dell MFP 1600n)
  • On the menu at the top click Printer->Properties
  • Click the tab at the top Labeled Advanced
  • Change the driver and Click Apply
This should fix your problem.
Nov 08, 2008 | Dell 1600n All-In-One Laser Printer
Stopped printing PDFs and Web pages
those your printer support wireless printing? if not try to check if it is bluetooth capable
Jan 09, 2008 | Brother HL 1440 Laser Printer
Dell 1600n All-In-One Laser Printer Logo
1,712 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
