Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
No pic on the screen,the set blew up and i replace the capitors and all the burn styy yet its turn on and no pic
  • Sony Master
  • 586 Answers
If you change the capacitor...Did you clean the oil of the capacitor from its surrounding area, because due to oil it could short the components, Check first Filament is lighten-up ? If yes then check ABL Voltages, if filament voltages not present check horizontal out put transistor. and check also safty resistances in surrounding area of H OUT Transistor.
Hope this will solve the problem.
Thanks for using fixya.
Posted on Jul 24, 2009
I was watching tv this morning and my set made a loud popping sound and the screen turned black. A red light appeared which read lamp and there was a burning smell. I unplugged the tv waited for a few...
The lamp is most likely needing replacement. Replaceing the lamp is a very easy proceedure on that model.I am pasting a pic where the lamp cover is located on rear cover. Remove the screw and the lamp is behind the lamp door.
Jun 08, 2011 | Mitsubishi WD-57734 57" HDTV
My Samsung LCD TV (40A450) 40 inch, when switch turn on after 2-5 second it turn off, no red light. when i remote to switch on then the red light is on and then press on again the lcd tv on after 2-5...
The capitors on the back might be bad this I have fixed on these tv's many times. That could be one of the problems and the capitors are on the power board inside the tv. If you do not know how to work on electronics I would have a pro do it they contain hight voltage so be careful if you try to fix it yourself.thanks
Oct 06, 2010 | Samsung LA40A450 40 in. LCD TV
My tv made a popping sound, the screen went blank
Any set is repairable. It is the question of the cost and the availability of replacement parts.
It sounds like a component overheated and blew. Most likely there will be collateral damage where other components will also be damaged.
The failure could be in the power supply, or in any of the main drive circuits in the set.
You will have to call for a service estimate. In considering the age of this set, my preference would be to go out and get a descent LCD or Plasma set. The picture quality and performance of these new sets are far superior to the one you have!
Jerry G.
Nov 14, 2009 | RCA D52W23 52" HDTV CRT TV
Tv doesn't turn on at all you can only hear a click when plugged to the wall outlet. The stand by light flashes twise
Please ittimate exact model of your Sony TV that would be written on sticker pasted at lower rear side to find out any solution for you.
Thanks.
Sep 04, 2009 | Televison & Video
When set cold it doesnt have pic
check capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is Bad so replace other 2 as well.2200uf 16v and Two 220uf 35v.
Jan 15, 2009 | RCA D61W20 61" Rear Projection Television
No pic No sound
your bulb is connected to all the audio
the bulb blew out and you need to have it replace local cuircut city has a repair man on call for this
Feb 16, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Rca scenium 52 inch replacement screen
I`ll have to be the bearer of bad news, the image is not burned onto the screen it is burned into all 3 of your picture tubes, which basically means the set is junk because the cost is too high.
Nov 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
AKAI FIX
My set had the same issue with the picture and burning smell. On my set, I just removed the cap and the set works great without it.
Aug 08, 2007 | Akai PT4799HD Rear Projection Television
CUT OFF TO STANBY
See Speargunner Oct.26,2007.................................T.
Jan 08, 2007 | Pioneer PRO-99 TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
