Question about Dell Latitude D510 Notebook
D520 setup locked, cannot change boot order or re-install os
Hi, i got a d520 from cash converters and it's got an admin password which doesn't allow you to change the boot order or reboot from within windows without the admin password, please advise - someone!
  • Anonymous Mar 23, 2014
    My son changed my password and now he can't remember what he changed it to,is this somthing I can do myself or would I need to take it to shop
    President:
  • 1,383 Answers
Here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Posted on Jul 24, 2009
Boots up but goes to the xp screen and then shuts down and restarts. what do i do?
You will need your XP CD to run a Repair install.
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will need to press enter to setup Windows XP.
3. To setup Windows XP now and Repair Install, press ENTER. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read the fix at the end of this post.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
If you don't have an option to repair, try this:
1. Boot with XP CD.
2. Press R to load the Recovery Console.
3. Login to the Recovery Console using your Admin password if needed.
4. Type bootcfg
5. This should fix any boot.ini errors causing setup not to see the XP installation.
6. Try the repair install again.
If the Repair is still not an option, try the following:
1. Boot with XP CD.
4. If the CD letter is K: give these commands
* copy K:\i386\ntldr C:\
* copy K:\i386\ntdetect.com C:\
While still in the Recovery Console, try this as well:
1. Type: attrib -h -r -s C:\boot.ini del C:\boot.ini
2. Type: BootCfg /Rebuild
3. Now Restart and try the Repair Install again.
Feb 23, 2011 | Gateway 704GE PC Desktop
I cannot log on, i cannot remember password
Hi.
If you can not remember the password, try logging into another user account with Admin rights and change the password for your account of there is another admin account in the computer.
Other option, as computers will have a default admin account, try booting to computer to safe mode, generally the account is not password protected until the user decides to assign a password.
Finally, if nothing works, you may use third party applications to boot into the Computer( e.g. Nopix).
Otherwise, use a OS disc and format the computer reinstall the OS.
Thanks!!!!
Dec 30, 2010 | Computers & Internet
I can't remember my log on passwaord for logging on ...I tried new admin password and reset pasword but when it loads up it goes right back to my name and asks me for my password ...I think my little brat...
Windows Password Recovery is right what you need in your case. The program is designed to reset Windows login password once you accidentally forgot it or have no access to your system. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove your forgotten password.
Jul 26, 2010 | Dell Inspiron B120 Notebook
Im locked out on administrator account
Try to boot to Safe Mode and then try to boot to admin if it will not try to boot to account user and then set an admin rights to it . If it will no allow you then it will be a posible OS reinstallation
-ERNZ
Feb 03, 2010 | Sony Computers & Internet
Can't get past passwords
Had the same problem. The password is in the software. You need the EXACT same OS install disks. Check the web as to the buttons you need to push when starting and it will boot off the CD. Then you need to do something that erases the startup password, under some TAB on the startup screen.
http://support.apple.com/kb/HT1352
Passwords are CASE sensitive.
Adam and adam and ADAM are different !
Jul 27, 2009 | Apple Power Mac G5 Desktop
Boot problem
open your bios setup and check the cd rom is recognized and check the boot priority is set to allow to boot from the cd rom first.
Feb 20, 2009 | Dell Computers & Internet
Os keep restarting. on boothing the laptop, the windows starts and the user interface loads. when ask for username and password, on entering the username and password, the laptop restarts.
From my point of view I think the Operating system needs to be Repaired and below is a guide on how to repair
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press ENTER to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R", (you DO NOT want to load Recovery Console). I repeat, DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read WARNINNG #2
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. After the installation is over the system will reboot.
Enjoy
If This Solution has Worked Please RATE ME!!!!!!!!!!!!!!!!!!!!
Oct 22, 2008 | HP Compaq Presario 2200 Notebook
Acer ASPIRE 4720z laptop
sorry to tell you that you will need to reinstall windows.
thats the only way
cheers
Jul 29, 2008 | Acer Aspire 9300 Notebook
Imac motherboard
i have a aple imac and i forget the admin password and i cand log me in
can you help me
Jun 29, 2008 | Apple (661-2795) for iMac Motherboard
Dell Latitude D510 Notebook Logo
1,364 people viewed this question
Alun Cox
