Question about Mitsubishi WS-55809 55" Rear Projection Television
Strange problem.. Hello, this is my problem, only one component works. the other 3 the picture looks like if the colors were reversed?? that is the best way I can describe it, the picture looks like the movie sin city... almost cartoonish.... it seems like the colors are off.... I really hope someone knows what I am talking about...the sound works perfectly.
  • Anonymous Jan 15, 2009
    My TV the picture look like a cartoon or an oil painting.
    Habit-Forming:
  • 76 Answers
RGB cable not in proper position.
Posted on Jan 23, 2009
    Genius:
  • 1,153 Answers
Can you take a picture and post it?
Posted on Nov 30, 2007
Screen has reversed colors (appears to look like a color negative). Everything seems to work ok. Repairable?
hello , just you need to enter to the picture options and change the display screen or display color , or change the mode it would be an NTSC mode you should change it
Feb 11, 2016 | Vizio VO370M LCD TV
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Hello, Ive bought a new Sony Bravia KDL37EX402 television a while back and hooked it up to my computer via hdmi. When i turn on the television it blinks after 3 to 5 minutes from black, back to the...
Sounds like something must be loose. Try seeing how secure the hdmi port is on both ends first, unplugging them and then firmly plugging them back in. Then if the problem still persists, try unplugging the T.V. for a solid minute and then plugging it back in. If it still occurs, something might be loose on the inside, and you'll probably need some outside repair work done. If you purchased a warranty then you should be covered. You should also be covered if you didn't but the T.V. is less than a year old.
Jun 07, 2011 | Televison & Video
Picture gets blurred and then disappears.
christian204, Your unit may be 5 -6 years old, and may have developed a problem with it's internal "switch-mode-power-supply" and will need good CCFL backlit lcd monitor tech to repair it. When strange and wierd things start to occur on lcd screens the first place to look would be the SMPS. 12fixlouie
May 11, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
My Samsung HLP4663WX has no picture, can't power off
it may be a bad DMD board. This is usually the problem when you get the three lights of death.
Sep 17, 2009 | Samsung Televison & Video
Viewsonic Projector not displaying RED
Hi there
This could be a problem on the Mainboard - because all the proccessing from your inputs is done on the Mainboard.
Try replacing it , I'm sure you'll have joy then.
Dec 28, 2007 | ViewSonic PJ551 Multimedia Projector
Color picture for my wii
maybe the component cables are not working, try buying a new component cable.
Dec 26, 2007 | Nintendo Wii Console
Colors
Hi, This sounds like a color driver problem with the RED. I will assume that the blue is good since yellow will only be present if the green and blue are both ok. Below is a copy of my response to a similar post at http://www.fixya.com/support/t181021-zenith_a25a11d_no_red_color "...If you are comfortable working with a soldering iron, a continuity (VOM) multi tester and a fair knowledge of electronic components, then perhaps you can repair the missing color red. You have to open the unit, expose the small printed circuit board that is attached to the small end of the picture tube. There will be many components present but you will need to focus yourself on three (3) transistors that are bigger than the others sometimes with an aluminum heatsink. It is also possible that instead of 3 transistors you will have one power IC. In any case these control and provide the drive for the 3 colors of your picture tube: red, green and blue. One of them is either dead or suffers from cold solder to any or all of its pins/legs. You have to visually inspect the solder joints of these big transistors/IC and determine if any is dull in color, loose of simply not connected. You may even try the shotgun approach and solder each of the pins/terminals/legs just as long as you don't cross solder creating a short between pins/legs. If this works, you're set, if not: You have to check with the use of the VOM and determine which of the 3 transistor is defective. If you are familiar checking continuity of base to collector to emitter and reverse, again you're set, if not perhaps you check all three and compare which have the same reading from the same position and which is different. Pls keep in mind the transistors have forward and reverse bias readings. If able to determine defective component, desolder, replace and solder. If it were an IC, replace the entire pack. If the above would make you uncomfortable, pls ask for the services of a qualified TV repair man and explain your problem..." Hope this give too an idea. Good luck and pls post again how things are or if you need further information. Kind regards.
Aug 20, 2007 | Samsung SyncMaster 753S 17" CRT Monitor
Zenith A25A11D No Red Color
Hi, If you are comfortable working with a soldering iron, a continuity (VOM) multi tester and a fair knowledge of electronic components, then perhaps you can repair the missing color red. You have to open the unit, expose the small printed circuit board that is attached to the small end of the picture tube. There will be many components present but you will need to focus yourself on three (3) transistors that are bigger than the others sometimes with an aluminum heatsink. It is also possible that instead of 3 transistors you will have one power IC. In any case these control and provide the drive for the 3 colors of your picture tube: red, green and blue. One of them is either dead or suffers from cold solder to any or all of its pins/legs. You have to visually inspect the solder joints of these big transistors/IC and determine if any is dull in color, loose of simply not connected. You may even try the shotgun approach and solder each of the pins/terminals/legs just as long as you don't cross solder creating a short between pins/legs. If this works, you're set, if not: You have to check with the use of the VOM and determine which of the 3 transistor is defective. If you are familiar checking continuity of base to collector to emitter and reverse, again you're set, if not perhaps you check all three and compare which have the same reading from the same position and which is different. Pls keep in mind the transistors have forward and reverse bias readings. If able to determine defective component, desolder, replace and solder. If it were an IC, replace the entire pack. If the above would make you uncomfortable, pls ask for the services of a qualified TV repair man and explain your problem. Hope this works out for you and give you some ideas. Pls post again how things turn up, good luck and kind regards.
Aug 12, 2007 | Zenith A25A11D 25" TV
Loss Of Blue Color
The loss of blue could be one of 3 things. First of all if you are connected to a HD cable box or a HD sat. recvr. using component cables. Make sure the BLUE connection hasn't fallen out or is loose. The possibilities is the blue CRT (picture tube) itself or something in the blue CRT driving circuit.
Feb 25, 2007 | Toshiba 57H84 57" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
