Question about Husqvarna Garden
WINDING NYLON CORD ON TO EIT250 STRIMMER HASQUVANA
  • 112 Answers
The spool usually has an arrow on it showing you the direction
Posted on Jul 24, 2009
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
My strimmer releases nylon cord involuntarily. This is without tapping it on the ground.
Hi Peter:
Check to see if the spring under the "bump" mechanism is missing, or not extending adequately. You could try stretching the spring a bit to see if that would help.
May 13, 2015 | Office Equipment & Supplies
How do I replace cutting head in a Flymo contour 500 strimmer?
Stan try winding the cord in the opposite direction. It may just be wrongly wound.Also make sure it's the right diameter.
Jun 27, 2014 | Garden
Once i cut strimmer wire to correct length, i then turn on power on strimmer, and without the wire touching anything it pops out long again.?
Ian your'e either not winding it the right way or your not getting the head to click in properly. Try winding the cord the opposite direction first.
Sep 05, 2013 | Garden
Trying to undo the cord thing and it just keeps turning and won't come off
To insert a new cord, hold the round plastic container where the nylon cord comes out so it stops turning, then you can unscrew the bottom part of the plastic holder (retaining screw). The cover and inner reel will come off so you can wind new nylon cord onto the reel. Insert the ends of the nylon cords into the outlet holes and replace the cover and retaining screw.
Oct 04, 2012 | Garden
Pull cord on homelite ut20006 trimmer
on the side where the pull cord was remove casing pull the cord through the hole on the casing wind the spring back on the strimmer not to tight but tight enough for the cord to return once pulled. Attach the cord onto the spring this will be obvious there is a little hole the cord goes through then pull a bit of cord through tie a nott then pull the cord back so the nott is tight against the spring ,let the spring spring back the gord shoul wind onto the spring reattach the casing and job done hope this helps
Apr 21, 2012 | Homelite Mighty Lite Lawn Trimmer
Broken pull rope of Mantis Tiller
Remove the starter assembly from the side of the engine. Remove the balance of the old cord from the spool and purchase about 1-meter of replacement cord from a saw shop (it should be nylon, not cotton). Insert the new cord into the center slot/hole in the spool, melt the end, and tie an overhand knot. Wind the cord around the spool several turns in the same direction as the old cord, then pull on the cord to wind the return spring inside the spool. Wedge the spool to prevent rewinding, then continue to wind the cord until about 8-10 inches are left. Feed the cord end through the cord port and into the handle. Melt the cord end, then tie an overhand knot and pull the knot back into the cavity in the handle. Remove the spool wedge and test the pull of the cord--it should pull out smoothly and return fully without slack. Hope this helps!
Dec 11, 2010 | Garden
GL 320 String trimmer - nylon string keeps breaking
It sounds like the sting is wound backwards. Try winding a short piece in the opposite direction. If it is backwards, it will be gone in a hurry.
Apr 16, 2010 | Black & Decker String Trimmer Cordless 12"...
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Garden Logo
293 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
