Question about Brother HL-2040 Laser Printer
Red Priner LED Wont stop flashing
I have recently changed the toner on my Brother 2040 only to find it won't stop the red LED Printer flashing despite having a full paper tray. Subsecquently I cannot print anything
    President:
  • Brother Master
  • 1,447 Answers
It is problem paper jum.please chack it then solve your problem
Posted on Jul 24, 2009
All the light flashing
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Brother HL-2040 Laser Printer
Brother HL 2040 drum light flashing after drum replacement
The drum light is triggered by a page counter. To reset it, hold the GO button with the drum door opened until the light goes out (10 seconds). Close the door and it should be reset.
Aug 07, 2009 | Brother HL-2040 Laser Printer
Paper led light wont stop flashing
Pull the tray out and make sure the back guide is pushed against the paper. The back guide tends to move easily on these models
Jul 15, 2009 | Brother HL-2040 Laser Printer
Won't feed paper
It has toner? if not replace new one. If it has toner then try to remove the catridge and place it again. This might help you.
Mar 02, 2009 | Brother HL-2040 Laser Printer
Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Oct 23, 2008 | Brother HL-2040 Laser Printer
Toner light stay on
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Jul 29, 2008 | Brother HL-2040 Laser Printer
Won't print
This indicates that the fuser req' replacement but it can also be
a mpcb fault.
If the problem occured during a flash storm i would go for the
mpcb.
mongrelken.
May 21, 2008 | Brother HL-2040 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
BROTHER HL-2040 LASER PRINTER- TONER LED INDICATOR STAYS ON AFTER I REFILLED THE TONER
Dont recomend refills causes too many problems, like you are experencing, put in a real brother toner should fix problem.
great link to explain of lights on panel
Dec 18, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
355 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
