Question about LG M6100 Cellular Phone
Any service center in pondicherry ?
When i flip on or off the phone display twisted like in to mirror view . what i can do ?
Id like to help but probably need a bit more detail, im just not sure what you mean by that statement
Posted on Jan 09, 2008
I want hp laserjet p2055d printer mirror printing solution
Mirror solution can be achieved by the position of inserted paper in the machine's tray.
Reference is printing in the latter head.
Feb 19, 2017 | HP Office Equipment & Supplies
Acer service center in pondicherry
At the exact "Center" of Pondichareri town.
Sep 07, 2014 | Sony BRAVIA Televison & Video
Driver side mirror replacement
    • 1
Remove thedoor panel. Refer to your Honda Accord repair manual for theinstructions in removing the door panel. Unhook the rods and connectors on theinside of the door panel and set it on the floor.
    • 2
Remove thefilm covering the access to the side mirror. It's difficult to avoid damaging thefilm while removing it so you will need to purchase a new piece of filmcovering when you buy a new side view mirror.
    • 3
Reachthrough the service hole into the mirror housing with a screwdriver. Loosen thescrew that holds the mirror. Twist the screw out with your hand.
    • 4
Reacharound the door and support the mirror with your other hand. Continue to twistthe screw out, then catch the mirror as it drops out when you remove the screwcompletely. Put the screw in a safe place so you don't lose it.
    • 5
Installthe new side view mirror by positioning it where the old mirror was. Insert thescrew you took out in Step 4 and twist it in with your hand. Insert ascrewdriver into the service hole to tighten the screw.
    • 6
Replacethe film covering that was damaged when you took out the old mirror. Push itinto place in the indentation on the door.
    • 7
Sit in thecar seat and adjust the mirror so you can use it properly.
Jul 06, 2012 | 2005 Honda Accord
Meade ETX-90EC . i cant see through the telescope at all and the focus doesn't work at all. their are sounds if pieces "clanking" inside when it is adjusted into view
The flip mirror has fallen off inside the scope. This must be returned to Meade for repair. Here is their customer service phone number:
Sep 12, 2011 | Meade ETX-90EC (325 x 90mm) Telescope
How to fix the problem of the screen viewing is now like a mirror effect to the objects it is seeing and the wording is viewed also like you would see it looking through a mirror. Now if you flip the view...
Panasonic Viewfinder - Mirror image:
Although I don't own a Panasonic, my Samsung and JVC camcorders have this flipped image function, so I guess most are similar in theory.
The mirror image is a function used for taking selfies, or where you want the subject to frame themselves while previewing the image on-screen.
This only affects the viewfinder screen, not the saved video or still, which remains as normal.
To correct this, you need to navigate to the 'settings' menu, exact location depending flavor of camera.
There should be an option for "self-portrait" mode or similar.
Switch this back to normal mode.
Why mirrored?
When screen is rotated 180 degrees to face subject in normal mode, they would see an inverted image, so the "selfie" function flips the graphic to compensate.
Dec 18, 2017 | Panasonic SDR-S150 Flash Media Camcorder
Hi, We cannot find JVC service center in your town. But you may try this tips : Once you plug in to power outlet Check power on your charger. If there is, connect to your camcoder. Turn on your camcoder. If it can turn on , your battery is flat.
Nov 30, 2010 | JVC GR-DX97 Mini DV Digital Camcorder
My LG360 screen is flipped and mirroring words backwards
hi,there are there kinds of flipping screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted damage LCD the phone will detected,and thirdly, The flex of the phone.
The flex is connected to the screen and it makes the screen display,if the flex gets damaged it will make the screen display be affected.
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | LG CF360 Cell Phone
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
2 Press PIC. FLIP to change the
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
4 Press c/d to select the desired
picture flip setting, and press
5 Press MENU to return to the main
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Negative display on a screen
The flip models phone some times fails the display so please change the display in your nearest service center
Jun 04, 2008 | LG VX8300 Cellular Phone
LG M6100 Cellular Phone Logo
82 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
