Question about Behringer Music
I cant find a user manual for a behringer intelligate noise gate could you suggest where i can get one
  • Behringer Master
  • 5,603 Answers
Only thing online is the spec sheet. Normally one using this device would know how to use it and the controls are really simple.
A user manual would NOT say very much as the use would vary so much. I would recommend searching for "noise gate usage" or similar GENERAL information. The controls are so few and simple anything you find will usually apply. You might search for a manual for another brand that might give information you need. The concept of these devices is simple and user manual will have a lot of commonality.
Posted on Jul 28, 2009
\frequent break down of 60n60c2 semiconductor
I would check the source going to the gate because if the gate isn't open you would get no output. The gate acts almost as an on off switch. Make sure the gate has voltage, if it doesn't, it would not operate. also, make sure to be testing voltage on the emitter which is pin 3. In other words, the gate is required for triggering.
Mar 01, 2013 | Behringer EUROPOWER EPX3000 Stereo Power...
10w 22rj wire wound resistor
When thosse resistors (precharrging of main input filters) burn up there is major damage. The IGBT's are usually gone... replace with APT28GA60BD15... the switching regulator IR2153 is gone... one or more of the 2SA1020-Y and the 2SC2655-Y gate drivers are gone. One or both of the DL4148 speedup diodes for the IGBT gate drives will be gone. The Wirewound ceramic resistors either 10 or 22 ohm 10 watt radials... Use:
http://www.mouser.com/ProductDetail/Ohmite/TWW10J20RE/?qs=GcOFt9%2fAxQHny%252b35G6iehQ%3d%3d
This is 20 ohms, however Behringer uses from 10 to 22 ohms in these units... 20 works fine as does 10 ohms. If you have toruble getting schematic let me know.
Aug 22, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
My mdx 1600 compressor goes off on one channel. if you switch off then back on it comes on again
Make sure all your audio interconnects are either XLR or TRS cables to avoid noise that might cause this. Also make sure ALL and I do mean ALL interconnected sound equipment is powered from the SAME receptacle OR power conditioner module. Powering equipment from buillding receptacles at opposite ends of a room is asking for trouble.
Aug 02, 2011 | Behringer MDX1600 2 Channel...
There are two resistors 310-3 10R on the power supply of the Europower pmp 5000, i need to know if it is 330k or 330om.
The schematic for the power supply does NOT show resistors in the 310-3... Where are these in the circuit... IF THESE happen to be the gate drive resistors for the IGBT's they are 33 ohms. If you have hasd a failure in this area there are other parts that typically get destroyed, including one or both the speedup diodes at the same gates; Here is the complete PMP5000 schematic:
http://elektrotanya.com/behringer_europower-p0569_hca2400_sps1000_dpx_pmp-1280s_5000_sch.pdf/download.html
Scroll down to "get manual" and cliick to download. IGNORE other download links. If you need help restoring the PSU get back to me.
Jul 20, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Copy of Behringer EM600 operators manual
On the following link you can find a digital copy of the user manual for a Behringer EM600:
http://www.americanmusical.com/ItemFiles/Manual/BEH%20EM600.pdf
May 30, 2011 | Behringer EM600 Echo Machine Ultimate Echo...
My behringer djx700 does not work properly 2 use the effects u have 2 plug an rca into the booth output on the back but then nothin else works and i can only here my left turntable in my head phones there...
Semiconductor things involved with sending the booth signals into the mains are:
IC2 which is a 5241 gate controlled by MIC_ON.
IC30 4580 summer for MIC and BOOTH.
IC53 4580 inversion and gain control.
IC39 4580 MAIN output drivers.
May 13, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Fuse and fuse holder needed for Behringer 3000 pmp mixer
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
666 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
