Question about Nokia Cell Phones
Nokia E65 appears with the message ''Memory card in use by another
My nokia E65 keeps coming up with the message ''memory card is in use by another application'' when I connet via USB and select 'Data Storage'. This happened after I changed the font type using kaosbp's method. I have tried restarting the phone without any luck. How do I fix this!! Please help!
Nokia E65(memory full close some application or try again)
Change your Nokia E65 Message Memory.
for that you should go to message & go to options select settings there you'll find other select it in that you'll get memory in use default phone memory is selected change it to Memory card your problem will get resolved.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 18, 2011 | Nokia e65 Cellular Phone
I have a nokia e65. My problem is that, when an incoming try to connect my device it says (Telephone: Memory full close some application ) although there isn't have any running application i can found...
I'd suggest installing all applications on your memory card, and moving all the files on your phone to the memory card along with all messages.
Step One - Go to Messaging (Meesag. on Main)
Step Two - Hit Up Options > Settings > Other
Step Three - Go to Memory in Use which will say "Phone Memory" and select your memory card.
Step Four - It will now ask if you want to move your messages over to the memory card (yes)
Step Five - It will ask if you want to keep your messages on the phone as a backup (no)
May 13, 2011 | Nokia e65 Cellular Phone
My nokia e65 memory reads "no memory inserted", but i have a 2gb sd micro which was inserted by the manufacturers. However the memory chip is accessible on the computer . Kindly sort me out
Remove the memory card and check using a memory card adapter on the card reader of the laptop. If the memory works fine with a scan and shows up well on the properties the capacity of the memory.Then replace the card back into the phone using the correct direction. Some times the direction is deceiving and so it might not read. Once in position if the card is not detected, then either the slot has a fault or the motherboard interface is defective.
Sep 18, 2010 | Nokia e65 Cellular Phone
Hw to recover deleted msg frm nokia E 65 phone
sorry but once any text messages, voice mail ext that has been deleted from any phone is no longer attainable, because the messages are not stored anywhere else on the service provider network. So once it is gone from the phone it is gone. sorry again.
Jan 15, 2010 | Nokia e65 Cellular Phone
I want to re format software on my nokia e65, i am updating the driver, while update is running i first get a message atleast 256MB memory required and then get a message, fatal error during installation....
Try the following steps:---
- power the phone off,
- press and keep down the keys green/talk and ‘3′ and ‘*’, and then power on the phone.
- release the keys when the formatting starts.
Regards, Biswa. Reply me is problem persists.
Sep 16, 2009 | Nokia e65 Cellular Phone
How can i select the memory (nokia e65) as phone and not the memory card? i'm trying to increase font size of my nokia e65
use nokia pc suite to install the apps and there you can specify where you want to install it..
to change the memory selection for your msgs, you can go to menu>messages>options>settings>other>memory in use
there you can change this for your sms..
cheers..
Jun 16, 2009 | Nokia e65 Cellular Phone
Corrupted Memory Card
hi thanks for using fixya!!
I suggest that you use a microSD memory card with only 2GB memory capacity.
If you need further assistance, let me know.
May 26, 2009 | Nokia e65 Cellular Phone
Nokia e65 is rebooting
most probably ur phone is infected with commwarrior virus ..... remove memory card and scan with norton antivirus ... meanwhile take back up of phone memory and format it using *#7370# ....default code is 12345..... After cleaning the card then insert it and check
Oct 17, 2008 | Nokia e65 Cellular Phone
Memory card problem for E65
format card by using card reader with fat16 file system
Sep 24, 2008 | Nokia e65 Cellular Phone
Memory card
Hi xxbooxx,
if ur memory card have erased only messages but not other mp3s and videos, etc. I have got the solution for it.
Go to messages, click options, and go to settings. Go to "other" option, there is a menu memory in use. In that change phone memory to ur MMC.
Then ur messages will appear in ur inbox.
Surely send me feedback and rate my solution too.
Dont forget to post clarification report of ur problem after the problem is solved.
Sajan(sajwhat_2003@yahoo.com / sajwhat@hotmail.com)
May 07, 2008 | Nokia e65 Cellular Phone
Cell Phones Logo
336 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
