Question about Makita 12V Cordless Impact Driver - 6980FDWDE
Disassemble a Makita 6980FDWDE Impact driver
I'm trying to disassemble a Makita 6980FDWDE impact driver. It does not have the 4 screws holding the front housing. The schematic appears to show the housing to have internal threads but I can't get the it to come off. What do I need to do?
For de assembling you first have to open the hammer case .the hammer case is fastened on the thin plate visible from the out side in anti clock thread .
so to open it first secure the thin plate in a vice and the using a wrench or universal channel lock turnr the hammer case counter clock wise to unscrew it . once the hammer case is removed you can see the four screws holding the thin plate which is the internal gear case with the plastic body, wicked isnt it , any ways it will solve your problum.
Posted on Mar 19, 2013
    Sergeant:
  • 384 Answers
Sometimes fasteners are hidden under labels.
Posted on Jul 24, 2009
When I press the power switch it starts to work at maximum rpm
The variable speed function is controlled by the switch. On rare occasions you can remove the switch, spray it with electronics cleaner and blow it out well to get it to work again. Usually you have to replace the switch. The switch for your impact driver is Makita part number 638326-6 and runs about $65.
Jun 08, 2012 | Makita 6980FDWDE 12V Cordless Impact...
I have a pear 6980, and it works just high speed and you can control the speed I wanted to know what can I do if I can fix it myself
Jun 06, 2012 | Makita 6980FDWDE 12V Cordless Impact...
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
How to pull apart makita 6980 impact wrench
the battery is removed. remove all screws around the outside of the drill/driver. the side comes off. the motor is a johnson motor connected to the planetary drive and hammer/anvil assembly. the motor drive extends inside the anvil via one gear off the motor. the hammer and anvil come out as one piece. if you depress the center of theanvil with an arbor press, two ball bearings come out and the escapment comes out with the spring. now you can clean the inside of the hammer and gears of the hammer drive.
Oct 20, 2009 | Makita 12V Cordless Impact Driver -...
Disassemble , houseing makita Model 6935FD Cordless
I would recommend going to Makitatools.com and typing in your model number for a schematic. Basically all you have to do is remove the 4 screws on the front holding the gearcase and then remove all the other screws holding the handle halves together. Let me know if I can help
Jul 14, 2009 | Makita 6932FDWDE 14.4V Impact Driver
Makita 12v impact driver- no reverse
I would suggest that you go to Makitatools.com and type in your model number and look at the breakdown for complete disassembly procedures. The only problem it could be it the tab on the switch or the shift lever is broken I would have to think it is the switch. Let me know if I can help more.
Mar 29, 2009 | Makita 12V Cordless Impact Driver -...
Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Dec 31, 2008 | Makita 12V Cordless Impact Driver -...
Can't separate case to replace broken switch
Have you removed the front housing? It has 4 screws that go into the handle halves and must be removed. As far as internal clips there are none. If you removed the front sometimes the handles stick together and you have to hold each piece and gently pull apart. Hope this helps
Sep 26, 2008 | Makita 12V Cordless Impact Driver -...
Makita 12V Cordless Impact Driver - 6980FDWDE Logo
828 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
