Question about General SG24/GH Surface Grinder: Honda GX340 Series 11 Hp Gasoline Engine
Honda gx340 valves
Hi im just wondering how do you ser up the valves in a honda engine
  • shanecullen Jul 24, 2009
    can i ask what do u mean by TDC
    that great im going to try that now ( im just wondering were the TDC is on the engine.
  • 6,674 Answers
The piston, not flywheel, at 1/4" past TDC on power stroke. With feeler gauge @ .005" check gap between rocker arm & valve stem. Back off jamb nut then move adjuster to proper clearance, for slight drag of feeler gauge, then re-tighten jamb nut. May take a couple of tries to get it right on as tightening jamb nut will make slightly tighter on you.
Posted on Jul 24, 2009
My Honda gx340 is revving high all the time Can some one tell me y thank you
should be an internal govenor on a plant unit like that
there is a thicker than normal metal rod running off the carby to the motor and that is where you adjust the govenor
cant find good instruction how that governor is adjusted ..if adjusted the wrong way it will rev out may even throw a piston
then check carby idle adjustment
should hunt (rev up and down only slightly )as load changes
you tube
11hp Honda GX340 cold start
https://www.youtube.com/watch?v=i3_v68__X5o
Honda GX340 HGI Partsf21c43c2-def4-46c5-9224-ed46701c0c01.jpghonda-gx340-revving-high-all-time-some-qkhmqzcwln4tohiil4ndbnz4-2-2.jpg
Jun 22, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
What RPMis the max torque
the chart shows figures of 10.7 hp-8.0kw with a torque of 19.5 ft/lbs- 26.4nm at 2500rpms ( max net torque)
the chart shows gx390 is 11.7hp (8.7kw) but the torque is the same as the gx340
you can get these figures from world. honda com or by going google and typing in--torque range of honda gx 340 motor at max rpms
10 hp engines running at 2500 rpms will be good for gensets of 5kw continuous out put as most makes run that size engine
Apr 20, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
My kubota GS 160 need both valves shaved. Apparently Briggs use .010 on both and tecumseh use one at .008 and one at .012 so I'm assuming that's roughly within the guidelines as can't find specs.
kubota - kosfa industrial co., ltd.
www.kosfa.com.tw/_english/02_products/01_list.php?fid=3&carid...
If you have questions about the models or products that you cannot find in our ......Model: GD75; Category: ENGINE VALVE; Description: SHAVE TYPE S45C; ... Make:KUBOTA; Model: GS160; Category: ENGINE VALVE; Description: IN & EX.
how to adjust valves on honda gx, or chinese replicas ...
? 5:49
https://www.youtube.com/watch?v=xmXr4U5R8ak
Sep 18, 2011 - Uploaded by enginerepairguy
You need to fixed the camera or some one help .... Can incorrectvalve clearance cause this type engine to start on choke, and immediately stop? .... Honda gx160 carb rebuild part 1 GX200 GX240 GX270 GX340 GX390 ...
Jan 19, 2016 | Tecumseh Garden
Have honda gx340 11hp pressure washer and gas keeps going into oil?
Excessive fuel entering the inlet manifold, carby needle and seat not shutting of fuel flow , remove and clean fit new gaskets and needle and seat if worn.
Jul 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Pressure washer rope recoils to quickly when pulling to start
I'm sorry if I'm not quite understanding the question.
Are you saying the rope MAY be too short and so the amount of pull available is also shortened?
Feb 23, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
I have a Honda EP5000 Generator set with GX340 engine, the problem is that too much oil is discharging from OHV cover into the Air Cleaner via that rubber pipe and spilling out from it. Engine also smokes...
Hi,the quick,but not final fix for this issue is to use a oil additive similar the one-s from the cars,but make sure you are using the one required by the fuel type.The engine is worn out,needs overhaul,soon or later.Good luck,regards
Nov 01, 2014 | Honda 6kw 120/240v, Gx340, Recoil Start...
How to replace valve timing gear in honda gx340 engine
Align crankshaft and balancer gear first. Rotate crankshaft and align timing gear. Alignment mark may be hard to see on crankshaft for timinig gear.
Jul 09, 2012 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Motorturns over hard with pullstarter on my gx340 pressurewasher
You have a nice setup, lots of power. The honda gx340 has a compression release built into the engine so it should be relatively easy to start. With the pressure pump under load however, it will be very hard to pull the rope. With water connected hold spray gun open so water is running out tip and pull rope to start (for easy start, remove tip from gun) . If it still feels very hard to pull rope while holding gun open, most likely problem with lubrication in pump or engine valves are not adjusted correctly preventing compression release. If you suspect problem, go to store where you purchased the unit or any store that sells gx340 and pull the rope to get a feel of what force is required to start engine and compare to yours. Good luck.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
General SG24/GH Surface Grinder: Honda GX340 Series 11 Hp Gasoline Engine Logo
163 people viewed this question
Top General Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a General Saw Expert? Answer questions, earn points and help others
