Try connecting to the Internet through the ethernet port (via a cable). If Internet Explorer loads the target page then you have a configuration problem with WI-Fi access : The wireless security settings are not allowing the computer to access the Internet. If Internet Explorer does not connect with the cable then the problem resides with Internet Explorer. Try to reset the defaults. To confirm that download FireFox and use it. Besides you need two browsers just in case one acts up.
You have Number Lock set on your PC - Have a look for a key top right hand side, it will have something like NumLck written on the KEY - you may need to use that Key in combination with the FN key - bottom left of keyboard - there should be a light somewhere on the keyboard which goes on/off as you toggle the NumLck key.
You should see different coloured numbers on the key s*()UIOPJKLM
These are the numbers and symbols that will be displayed when the NumLock is used
i have the same problem.
I run the windows screen keyboard and i discovered that when i press
both r+t keys and u+y both shifts are switching on. i'm not able to switch
it off even using mouse on screen keyboard.
as temporary workaround i press fn key then i press shift on screen keyboard, then both shifts switches off.
i didn't fount full solution.
1. At the BIOS password
prompt ("PASSWORD = "), press and release the following keys,
one after another: Ctrl, Tab, Ctrl, Enter The computer's response
should be: PC Serial No.= XXXXXXXXX
Challenge Code= XXXXX XXXXX XXXXX XXXXX XXXXX
Response Code= 2. Get
response code from your local toshiba support center Then follow the instructions the support guy will give you to unlock the laptop
hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
