USING PRINTSHOP 22, WHEN I TRY TO ''SAVE AS PDF'' I GET A ''PDF CONVERTER ERROR'' STATING ''UNABLIE TO INITIALIZE PDF PRINTER DRIVER. TRY RE-INSTALLING.''
  • 164 Answers
Do you have a pdf software package such as Adobe Reader installed? If not, the software you are using provides that function but doesn't contain the necessary conversion app.
try this free pdf software
http://www.primopdf.com/
I hope this helps...
www.aa1consulting.com
Posted on Jul 24, 2009
I accidentally updated to adobe dc. It was a wreck. I have removed it. Now, I used to be able to save things I made to a PDF. I am getting an Error. It says
You don't want to be playing inside the Windows Registry unless you are very sure what you are doing.
Reload the program Adobe Dc and remove it in Control Panel Add Remove programs.
Then reload the version you had before.
FWIW, I got rid of Adobe. I use Foxit Reader which is great and not bloated like Adobe is.
I use this free suite of PDF Editors for opening, making and saving PDFs
Software995 toolset
Nov 06, 2015 | Office Equipment & Supplies
Which is the best PDF converter?
In word you when you go to save the document go to File>Save As and you should be able to save in .pdf format. Another option which many of the users I have worked with use a free version of CutePDF writer. This software acts as a printer so you open the document you wish to convert. Click Print, and select Cute PDF as the printer. It will then ask you where you would like to save the document and Boom! There is your PDF!
Feb 07, 2014 | Computers & Internet
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
May 14, 2011 | Encore The Print Shop 23 Deluxe Full...
I tried to install Printshop deluxe 22 on my new computer which has windows 7.it says that there is an error.what would you suggest
I suggest that you tell us EXACTLY what the error-message stated.
Or, start the Windows Program Compability Wizard, and tell Windows 7 that you want to install a Windows XP program.
Then, install the software.
Aug 22, 2010 | Broderbund The Print Shop 22 Deluxe Full...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I can't covert a project to PDF
You can reinstall pdf converter,or you can download a new pdf converter.I use advanced all to pdf 5.0,it is pretty good.Converted quality is fairly good: with text content, page layouts, images,and text hyperlinks preserved.I chose it because it is a standalone
application, I could run this program independently and needn't extra install Microsoft Office or Adobe Acrobat which costs hundreds of dollars.
Oct 06, 2009 | Broderbund The Print Shop 15...
Error when right click a word file and try to convert it to pdf
Use foxit pdf reader it will come up with Foxit pdf printer , you can easily save any document to pdf.
Oct 03, 2009 | Computers & Internet
My system is windows vista 64 bit. Print shop
you have to go to the help section or help tab at the top of your printshop window, on your printshop program...and then click technical support , and it will give you options...click on the option of troubleshooting and it will take you to the broderbund direct online troubleshooting page, and click on the appropriate option for windows vista 64bit, and it will walk you through step by step; which involves going into your printer port settings under control panel section of your computer, and just follow the online directions...I just did it and my newsletter on printshop 23 deluxe is now saving without problems!
Aug 11, 2009 | Encore The Print Shop 23 Deluxe Full...
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
