Question about Microsoft Windows Media Player
Troubleshooting windows media player
When i opens the media player it tells me that "the file wmploc,dll has a version number 11.0.6001.7000 where 11.0.6001.7004 was expected
    President:
  • 1,566 Answers
Try to do a windows update. Or reinstall windows media player. Or if still doesnt work, try this workaround:
http://www.mydigitallife.info/2009/01/06/fix-wmplocdll-expect-version-number-error-on-running-windows-media-player/
Posted on Jul 24, 2009
Windows 7 Media Player 12.0.7601.17514 configuration setting are corrupted and remain corrupted after resetting the Media Player to its default settings. How do I completely rebuild the default Media
You may be able to remove then put back WMP from Programs and Features in Control Panel. Click on add/remove features and you should see it there. Uncheck the box and apply. Restart afterwards then check the box and apply. May require another reboot.
Jan 14, 2013 | Microsoft Windows 7 Home Premium 64BIT...
When I try to open media centre I get an error message "SymSetSymWithAddr64 could not be located in the dynamic link library DBGHELP.DLL" How do I fix?
Most probably the DBGHELP.dll file located at C:\Windows\System32 is corrupted or outdated or wrong version.
By replacing the "DBGHELP.dll" with a good/correct version usually fixes the problem.
Read this thread how to replace the file, here
Hope it helps.
May 14, 2010 | Microsoft Windows XP Media Center Edition...
New computer dell inspiron 570 running windows 7-connected for 3 days. came back to use it this afternoon and the media player has lost it's sound and you can hardly hear the PC -the system tells me =media...
Microsoft Windows Media Player is a free media player software that comes with the personal computer version of Windows operating systems. The software supports basic file formats such as WMV, WMA, AVI, MP3, and ASF. The player included in Windows XP gives you the power to create your own CDs, search and organize digital media on your PC, and copy files to portable devices such as CDs and pen drives.
Fix Windows Media Player Problems
Corrupted and missing DLLs files, incorrect registry entries, and outdated files are some of the causes of Windows Media Player errors. Covered here are a few steps that you can take to fix common problems.
C00D11CD: Unknown Error
C00D11CD errors occur when an operating system component or some other program encounters an error and does not communicate it to Windows Media Player. Due to its generic nature and multiple reasons for occurrence, there is no specific solution to this problem.
If you encounter the error when trying to play an AVI or MPEG 2 file, then most likely, you do not have the correct codec version installed on your system. To fix a Windows Media Player problem related to codec, search for the required codec on the Internet, download it, and update it on your system to play the required file.
Windows Media Player uses Digital Rights Management (DRM) to authorize copying files to a CD or to download them from an online music store. If you do not have DRM authority to copy a particular song, you will not be able to play it and the error will pop up.
Windows Media Player uses the wmadmoe.dll file to encode files. If something goes wrong with this file, you may get the c00d11cd error when you try to copy songs from a CD to your hard disk. To fix a Windows Media Player problem in this situation, you must register the DLL file by running the command ‘regsvr32 wmadmoe.dll’.
80040155: Interface Not Registered
If this error occurs when you try to burn songs into a CD, then the most probable cause is that the required player files are no longer registered on your system. To fix this error, try to reinstall your Windows Media Player or download and install a newer version of the player, if available on the internet.
800C2EE2: Action timed out
This error occurs when your Windows Media Player is unable to connect to a server due to problem in the network, and therefore cannot play protected audio/video files that you download from an online music store. Incorrect Internet Explorer security settings might be the cause of this problem. To fix this, open Internet Explorer and select Tools-Internet Options-LAN Settings. Next, clear the Automatically detect settings check box.
C00D0FAA: Cannot rip the files
The error usually occurs when you try to rip CDs to MP3 format. Existence of entries from an earlier player version in the registry might be the reason behind this problem. One way to fix this problem is by adjusting the audio quality. However, if you want to maintain the audio quality, then to fix this Windows Media Player problem, open the Registry Editor by running the Regedit command and navigate to the subkey given below.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Sett ings\MP3Encoding
Here, open ‘LowrateSample’ and delete the value displayed in the Value Data box. Select OK and exit Registry Editor.
Many times errors also occur when there are corrupt files on the system or there are invalid DLL entries and other related incorrect entries in the system registry. For this, you must try to download reliable registry cleaner software from the Internet and scan your registry for invalid entries. Using registry cleaner software, you can easily and efficiently fix Windows registry problems, and make your PC free from irritating errors.
Errors can occur in Windows Media Player due to outdated files, missing or corrupt DLL files and incorrect registry entries. Most of the time, you can fix Windows Media Player problems by updating missing files or by upgrading the player to a later version. Additionally, to prevent registry-related problems, you can use a registry cleaner software to regularly scan the registry and eliminate invalid DLL entries and corrupt values from it.
Mar 06, 2010 | Computers & Internet
Acer aspire laptop...cant open media player...when i do it says file wmploc.dll has a version number endind with an 8 when it should end in 0...all other numbers are the same...
did you try windows updates are your automatic settings for updates are on you you also might of deleted the a file needed to open
Jan 30, 2010 | Acer Aspire 5315 Notebook
Whenever Windows Media Player tries to play I get this error message."The file wmp.dll has a version number of 11.0.5721.5268 where 11.0.5721.5145 was expected. Player must be re-installed. Have...
I always use VLC which is free download for all my video files. Make VLC your defalt player. You will find that this player is more versatile than Windows Media and makes it obsolete,.
Nov 22, 2009 | Microsoft Windows XP Home Edition
Wmploc.dll error
it means ur .dll file was corupted..just reinstall the wma player...
Jun 07, 2009 | Microsoft Windows Media Player
Error message: "The file wmploc.dll has a version number of 11.0.6000.6344 where 11.6001.7004 was expected. Windows media player was not installed properly and must be reinstalled. Do you want to inst
This is not a very common problem, but in all likelihood your Avanquest software has altered your Windows files in such a way that you cannot install your media player.
Most fix-it utilities make back-ups of your system files as they were BEFORE running the utility.
Check in your Avanquest application to see if you can restore your system to the way it was before running the application, then try reinstalling Windows media player.
Let me know if you need any further assistance regarding the above.
Best wishes,
Graemevm
May 21, 2009 | Microsoft Windows Media Player
Wmploc.dll has 11.0.6001.7004 when 11.0.6001.7004 was expected
Hi fcmx1
On Windows Vista:
  1. Reboot your system.
  2. Open cmd.exe as an administrator by selecting Start/All Programs/Accessories.
  3. Right click on Command Prompt and choose Run as administrator.
  4. Type in
    unregmp2.exe /UpdateWMPVersion
  5. Press enter.
On Windows XP and Windows 2003 and earlier:
  2. Select Start/Run and type in:
    %SystemRoot%\inf\unregmp2.exe /UpdateWMP
  3. Click Ok.
Does this help?
May 13, 2009 | HP W2007 Desktop Monitor
Unable to open Windows Media Player. Error “The file wmploc.dll has a version number of 11.0.6000.6336 where 11.0.5721.5445 was expected.”
I guess the best thing is to download the latest version of Media Player, and before you install it, you remove the version installed by the Control Panel/Add and Remove programs (and restart your system before continuing).
Here's a link to download the version 11 (even if there is 12 in the link).
http://en.softonic.com/s/windows-media-player-12
Oct 28, 2008 | Computers & Internet
System says that program not responding
From what you put on this, it seems that you have a KERNAL32 error.
Fault Module Name: kernel32.dll
the application being Windows Media Player
Application Name: wmplayer.exe
I've researched this thru microsoft and the best thing I can find
Go to Start - > Type Run in the Search Box - > type regsvr32wmp.dll
What operating system are you using? Because the KERNEL32.DLL file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (ME).
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Media Player Logo
168 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
