Problem with sound - Philips HTS3455 Home Theatre System
My Philips HTS3455 Home Theatre System, its been with me 4 almost 2 years i bought it in 2003. The system was working just fine the current had gone off and when it came on i have no sound. When i turn the Volume to max i can hear the song play very faint but before if i increase the volume to 10 it used be very loud. Kindly help me fix the problem its driving me nuts.
Many thanks
  • 3 Answers
This problem seems to have been solved on here for the HTS3450, but the HTS3455 has a different board layout inside the AV Subwoofer. I've replaced two problem capacitors, but still have the same faint audio problem. The subwoofer fan isn't operational either. I'm at a loss as to where to go from here.
Thanks,
Adam.
Posted on Jan 10, 2010
  • Adam Jan 04, 2011
    Still having same issues........anyone?
    You can't just buy a replacement board from anywhere?
    Scholar:
  • 113 Answers
Hi, I am sorry to say that there is probably a fault. First check the fuses if able (a possibilty). If not that then will need to go in for repair.
Hope that helps
Posted on Jul 25, 2009
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
Pinout for 15 pin audio connector on Philips
1=control (I assume this is some kind of digital signal to turn the amp on and off...?)
2=nc (no connection)
3=nc
4=centre
5=centre ground
6=digital ground (possibly not needed if you're not hooking into the sub...?)
7=subwoofer
8=sub ground
9=nc
10=left ground
11=left front
12=right front
13=right ground
14=right rear
15=left rear
A full service manual for the HTS3345 is available at http://www.scribd.com/doc/37538958/Philips-HTS3455
Apr 14, 2010 | Philips HTS3450 System
Connecting PC to the Philips HTS3455
Hum first,,, anytime you have 2 devices with sound running to a cable or ant equipted TV you will get a hum as they are grounded off curcuit. HumEliminator (radio shack). You didn't tell us if your PC had been enabled in control panel for either device. I have had no luck using the rear aduio output on any computer. Front headphone jack on PC does not need enabled and will work better for this. Unless you use a USC codet interface which is better yet for CD quality in sound. Also make sure the Aux inout is enabled on TV as well. Direct Input would be the same. Lastly,,you are 100% positive the backside is input and not actually out put or gaming inputs.
Mar 05, 2010 | Audio Players & Recorders
Philips HTS3455 max volume very faint music...
Thanks,
Adam.
Jul 24, 2009 | Philips Audio Players & Recorders
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
Philips HTS3455/98 System "NO SOUND" PlZ Help!!
There are two capacitors on the power board that are 470uf/35v. go to Radioshack and buy two catalog #272-1030 470uf/35v radial lead capacitors. if you have soldering wick and a soldering iron, then this will cost you under $3.00. when you remove them, the capacitors have a white strip with a negative sign on it. match this up with the shaded area on the board. put it back together, and it will work, and last a long time. I have this same system, and it wouldn't play any sound. so, I replaced the capacitors. Hope this helps!0ccab8c.jpg
Nov 30, 2008 | Philips HTS3450 System
I bought philips 5.1 home theatre for PC it is not supporting
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jul 02, 2008 | Philips HTS3450 System
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
408 people viewed this question
 Grubhead
Grubhead
