Posted on Jul 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FAax machine neither auto prints nor saves docs received?
Anonymous
Level 3:
  • Master 1,959 Answers
  • Posted on Jul 24, 2009
Anonymous
Master
Level 3:
Answers
1959
Questions
Helped
1215712
Points
7500
Sounds like the memory is full. Post back with the make/model for instructions on how to clear the memory.
Says receiving fax but doesn't print
Fax machines can be set to store documents, print docs or do both. If you set it to only print received faxes, it will try to print and give you some kind of error it if fails (e.g. no paper). Did you get an error? if not it either is set to store and not print, or it didnt store it and you have lost it. From the menus on the Epson, look for where items may be stored e.g. 'store' or 'mailbox' and check if there is any doc in there.
2helpful
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
I have a new iMac running OSX10.6.5 All of my saved Print Shop docs will not open. When I try to open them my computer opens my Adobe Photoshop Elements software and it says it can't read the doc. All my...
You have to change the file associations for them to open with Print Shop. Select any Print Shop document, right click and select Get Info. Under the section Open with, there is a dropdown menu that shows the programs that open that file type. Simply select Print Shop and click Change All... button. Click Continue at the prompt and Print Shop should open all those file types.
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
3helpful
I HAVE LOST MY MANUAL FOR THE DAK AUTO BAKERY BREAD MACHINE
I don't know what model do u have but here are 2 links that may help u.
They charge $1.85 to download and print
http://www.scribd.com/doc/18595002/DAK-Bread-Machine-Turbo-Baker-II-Model-FAB2000-Instruction-Manual-Recipes-FAB2000
http://www.scribd.com/doc/18594895/DAK-Auto-Bakery-Series-FAB-100-Instruction-Manual-Recipes-FAB100
Sending and receiving a fax.
Place document in top tray adjust guides around doc. making sure the doc. is facing either print up or down according to the machine orientation. Next enter the fax number dialing just as you would a phone and when finished press the START button and off it goes..
It keeps reading AUTO PRINT OFF
All you have to do is to switch between auto print off and auto print on.You do that by pressing the on /off button once and then it switch between settings,if you hold down the on /off buton it switchs off.By pressing the button once less than a second it will switch between auto print on or off.
Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT  I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
42helpful
3answers
Change auto print off to on
If it displays "AUTO PRINT: OFF" and only that, just press a single time the ON/OFF button.
If it also displays "REC'D IN MEMORY" it means there is a document already stored in memory. to print it go to MENU then with the arrows go to MEMORY REFERENCE. Press OK and then you will acces the MEMORY options you can print the memory list, print stored docs, and also delete the documents.
hope it helps
old marine
old marine
ZJ Limited
ZJ Limited
