Question about Philips Audio Players & Recorders
Philips HTS3455 max volume very faint music...
I have a Philips HTS3455 Home Theatre System, its been with me 4 almost 2 years. The system was working just fine the current had gone off and when it came on i have no sound. When i turn the Volume to max i can hear the song play very faint but before if I increase the volume to 10 it used be very loud. Kindly help me fix the problem its driving me nuts.
Many thanks indeed.
    Problem Solver:
Really i have same problem for this model
and there is not 470uf/25V exist in board,
what capicitor i change now ?
Posted on Oct 26, 2010
    Problem Solver:
  • 5 Answers
Check out this forum post, I think if you cange the capacitors it will work...
http://www.fixya.com/support/t1315155-philips_hts3455_98_system_no_sound_plz
Posted on Feb 24, 2010
  • 3 Answers
This problem seems to have been solved on here for the HTS3450, but the HTS3455 has a different board layout inside the AV Subwoofer. I've replaced two problem capacitors, but still have the same faint audio problem. The subwoofer fan isn't operational either. I'm at a loss as to where to go from here.
Thanks,
Adam.
Posted on Jan 10, 2010
  • Adam Jan 04, 2011
    Still having same problems.....anyone???
2 Suggested Answers
  • 3 Answers
SOURCE: Problem with sound - Philips HTS3455 Home Theatre System
Thanks,
Adam.
When I connect me ipad to the Philips mx5500D the sound is low
maybe your ipad's volume is low - volume settings for ipads are different when both plugged / unplugged
Oct 27, 2012 | Philips MX5500D System
I have a LG Record reciever home theatre model is LH-RH9691 and im having a problem with the volume only when the radio is working. It can only turned up slightly when set to max volume. But when...
in lg home theater system in video mode the complwte speaker will work and in mp3 only two will word .the radio get only a min volume in lg due to the range of antina
Apr 25, 2011 | LG Audio Players & Recorders
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
Hi, I own a HTSS3455 Home Theatre system since 3 years and it worked without any complaints since then but since last month I am facing sub woofer issues ..when I increase the woofer base volume above 5...
Hi, kumar,
I am also using the same model but i got problem in DVD player but my speakers are working fine. I am from Pakistan and here i didn't find the spare part of MPEG main board card. If you wanna buy my Speakers or if you wanna sell ur DVD player contact me on sajjadzaidi@hotmail.com.
Aug 25, 2010 | Philips HTS3450 System
Hi, I am sorry to say that there is probably a fault. First check the fuses if able (a possibilty). If not that then will need to go in for repair.
Hope that helps
Jul 24, 2009 | Audio Players & Recorders
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
Philips HTS3455/98 System "NO SOUND" PlZ Help!!
There are two capacitors on the power board that are 470uf/35v. go to Radioshack and buy two catalog #272-1030 470uf/35v radial lead capacitors. if you have soldering wick and a soldering iron, then this will cost you under $3.00. when you remove them, the capacitors have a white strip with a negative sign on it. match this up with the shaded area on the board. put it back together, and it will work, and last a long time. I have this same system, and it wouldn't play any sound. so, I replaced the capacitors. Hope this helps!0ccab8c.jpg
Nov 30, 2008 | Philips HTS3450 System
Connecting a psp to our unit?
The USB port is only compatible with flash memory drives and some card readers.
Jan 03, 2008 | Philips HTS-6500/37 System
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
617 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
