Question about Epson Stylus Photo R340 InkJet Printer
I had a paper jam which I cleared, will do test print, nozzle cleaning, etc but will not ptint from the computer or scanner
  • Epson Master
  • 511 Answers
Check connection of chip to head carriage. For printing, epson main board read ink level counter in chip. It may be have bad connection. Try to use another chip.
Posted on Jul 24, 2009
Print not clear, double struck, cartridges are new and sometimes paper jams
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/.../trble_4.htm
EpsonPaper does not feed correctly when using the double-sided printing feature. If one of the ... The ink cartridges are not empty. ... If the error does not clear, open the printer cover and remove all of the paper inside, including any torn pieces. Then ... If yourpaper jams frequently, make sure of the following: ... Load a new stack.
Epson Stylus COLOR 600, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...FAQs...
EpsonThis link provides access to Top FAQs for the Epson Stylus COLOR 600. ... I just replaced an ink cartridge and the printer still won't print correctly. ... [ Answer ]; The printer is not producing any black or color ink. ... [ Answer ]; I'm only getting partial printouts or a "paper out" or "printer off line" error appears. ... How do I clear this?
epson printer problems ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/23851
I loaded a new black ink cartridge into my Epson Stylus C86. .... hit this problem when we first bought it, apparently it needs all colours to print ... i am using Epeon L 110 printer The colour print was good before But now the colour print is not clear ... No paper jams (sometimes paper feeds sometimes it doesn't). it appears that ...
Jan 05, 2016 | Epson Stylus NX420 Inkjet Multifunction...
DCP-J125 Uable to print (36)
The message Unable to Print (followed by a two character code) will appear on the display for one of the following reasons:
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper, stuck in the machine
- Mechanical malfunction
The most common cause of the issue is dirt on the encoder strip. Clean the encoder strip by doing the following:
CLEAN THE ENCODER STRIP
NOTE: The images shown below are from the representative product. The customer's model may look different from the picture.
1. Locate a lint free cloth such as a T-shirt, DRY eye glass cleaner cloth, DRY monitor cloth or wash cloth.
DO NOT USE ANY TYPE OF PAPER PRODUCTS (EX: paper towel, tissue paper, napkin, filter, news paper etc.) This will help ensure the dirt is removed from the encoder strip.
CHECK FOR FOREIGN OBJECTS & PAPER JAMS
2. After thoroughly cleaning the encoder strip, look inside the machine and in the two corners for jammed paper or foreign objects and remove them if any are found. Pieces of paper may be jammed under the print head.
If the print head is locked to the right side of the machine, press and hold the STOP/EXIT key for 5 seconds. This will cause the print head to move automatically to the middle of the machine and allow you to look for debris in the right corner.
3. Leave the scanner OPEN and turn the machine around so you are looking at the back of the machine.
4. Open the Jam Clear Cover and look inside the machine for paper. Remove any jammed paper that appears; then close the Jam Clear Cover and turn the machine back around to the front.
5. Gently close the scanner cover and verify the error message cleared from the display.
If you cleaned the encoder strip ONCE and the message continues to appear on the display, clean the encoder strip again. It is common to clean the encoder strip multiple times to resolve the issue.
If you cleaned the encoder strip at least TWICE and the message continues to appear on the display, unplug the machine from the power outlet for 2 seconds and plug it back in to cycle the power.
TEST THE MACHINE
NOTE: After a paper jam has been cleared, the Brother machine may complete a 2 minute cleaning cycle to remove paper dust from the nozzles before printing.
May 01, 2012 | Brother Office Equipment & Supplies
While copying mode, and paper feeding into printer, the sheet was pulled to remove and it jammed causing an error message to be generated. (Contact Epsom support). After restarting printer, print comes out...
To clean your Epson Stylus > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
This will solve the paper jamming problem. Hope this helps, please rate if the solution was helpful, thanks!
Sep 02, 2011 | Epson Stylus CX6000 All-In-One InkJet...
Ix4000, paper feed jamming all the time
To clean your Canon Pixma > open a document (from the computer) and select print from the menu,
Sep 02, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Ink not showing when printing
You may need to perform a head clean especially if the printer hasn't been used for a while.
The following is for XP but Vista and Win7 should be similar.
Click start/printers and faxes, right click on your printer ans select Printing Preferences from the drop down box.
Select the Maintainance tab click on head clean and follow that up with a nozzle check test page.
You may have to perform several head clean processes, once you get a clear nozzle check test page printed you should be good to go.
TIP use only one page for the nozzle checks as each check uses a page, Just reload the paper again until satisfied.
Jun 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Green power light is flashing for no apparent reason
Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Jan 02, 2010 | HP DeskJet 3940 InkJet Photo Printer
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
HP DESKJET 3820 GREEN LIGHT FLASHING, WILL NOT PRINT.
Issue
Solution
Close the cover.
Issue
Printer is out of paper
Solution
Issue
Printer has difficulty picking up label media
Solution
Issue
Solution
  2. Press the Power button once. Wait a moment for the paper jam to clear.
Issue
Solution
Issue
Solution
Cyber kaka
Dec 08, 2008 | Office Equipment & Supplies
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam- now prints with lines
Paper jams are often caused by bits of paper left in the printer. If you can't get to it by opening any access panels, then the printer may need to be disassembled. Check all your access panels first. If that doesn't do anything, visit Staples or an Office Supply Store like that, and purchase a pack of Printer Cleaning Paper. The one I have, the paper is sorta folded like an accordian, and you get some spray to spray the paper. Run that thru the printer according to instructions a couple times. Are you able to remove your printhead? Check that for buildups. Lastly, how long have you had it? Canon printers offer a one year warranty. Good Luck!
Nov 17, 2007 | OEM Systems PIXMA iP3300 Photo Printer
Epson Stylus Photo R340 InkJet Printer Logo
98 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
