Very low sound comming out pioneer pl300
Tried on differents sounds systems same resaults , is there a volume control on this turntable ? when y put my finger on the stylus i hear a sound but very low .
What could be the problem .
Thanks Jack
  • 1 more comment
  • jacklacampag Jul 25, 2009
    Thanks for solutions , will try changing cartrige and stylus , I never pluged turntable to aux or tape inputs . By the way is there a test that I can do to find out if it is the cartrige or the stylus who are faulty .
    Jack
  • jacklacampag Jul 27, 2009
    Hi Ganx , my cartrige is an Audio technica AT 11E , both channels are the same ohms mesurements on the multimeter , can we presume at this point that the stylus only is giving this low sound volume .
    Thanks again . Jack
  • jacklacampag Jul 29, 2009
    Thanks so much , found a stylus for about $20.00 and everythings works well now .
    A chance we have Ganx and others who takes their own times to help and find solutions .
    Have a nice day . Jack
    Scholar:
  • 113 Answers
Hi Jack.
Just confirm that it is plugged into a PHONO input (designed for turntables) Cannot use AUX/TAPE etc type inputs. If not, you will need an RIAA preamp from local electronics/Audio store. If that is OK, then try replace stylus first and the cartridge (may be just easier to do both same time). No volume control in turntables and it can only be 3 things (generally) Input, stylus, cartridge
Best of luck
Posted on Jul 25, 2009
  • Garth Urie
    Garth Urie Jul 26, 2009
    Hiya Jack,
    If you have a simple multimeter, put it onto resistance and measure the ohms of the cartridge left and right. Both channels should be the same. It depends what cartridge so can give you an idea of what it should be.
  • Garth Urie
    Garth Urie Jul 27, 2009
    Hi Jack, at this pint yes probably. However if it is big story to order and get etc, it may be easier just to replace both??? Up to you, personally i would do stylus first though
    Cheers
Pioneer Pl990 turntable sounds awful.... I have a pioneer pl 990 record player connected to a pioneer amplifier and a sony CD player. when I play an LP, the sound is bass heavy and I can hardly hear t
When the turntable plays, do you get a howling bass heavy sound? Have you tried turning down the volume and bass? If that corrects the problem, you have what's known as Acoustic Feedback. Check to make sure the tonearm is properly set up first. If it is, please visit my website at Audioserviceclinic.com. You may contact me there. Thank you.
Dec 13, 2014 | Pioneer PL-990 Turntable
Too much bass
I didn't know that a turntable had bass control on it. If it has why not turn the bass down? I think it is your receiver not the turntable
Dec 30, 2013 | Audio Technica ATLP120USB Turntable
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
My Ion ittusb has no sound while playing or recording. But the software it will record and play back? Have used different makes of software. Even tried it on a laptop to see if it was a PC problem. have...
I am not sure what computer system or operating system you are using. If you are using a PC with MS Windows try to go to the control panel from the start tab. Double click on the sounds and audio devices icon. Click on Advanced in the master volume box. If any mute boxes are checked, uncheck them and move the volume to the top. Try your system to see if you have any output. I hope this helps since I did not see any recommendations to check the master volume mixer.
Jul 14, 2011 | ION Audio iTTUSB Turntable
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
Pioneer DEH-2750 - Very low volumed (Aud out L R) - no speakers s
The power amplifier is not working. Find a repair shop near you to find the repair rates, then decide if it's worth fixing.
Aug 09, 2017 | Pioneer DEH-2700 CD Player
I just bought a pioneer pl-200 turntable at a flea market. I plugged it into an old am/fm/8-track amp's phono input and I know the amp cranks on fm but on phono, it's very low sound. It does get louder...
Turntable signal outputs are very, very low amplitude and either have to pass through a pre-amp before being connected to an amplifiers "ordinary" inputs (e.g. aux), or connect to an amplifier's specific turntable input in order to give the "normal" levels of volume.
This is because the cartridge (the bit that has the stylus or needle on it) can only generate very small amplitude signals.
As turntables are now outdated, a lot of amps no longer have a turntable input any more.
Unless you can also find a cheap pre-amp or an old amp with a turntable input, you may have wasted your money.
Sep 21, 2009 | Audio Players & Recorders
No volume control
HI Phil...
The AUX input will not work with a turntable.
The turntable needs a pre-amp before you connect into the Soundspace.
Try www.needledoctor.com for a pre-amp
Apr 09, 2008 | Nakamichi SoundSpace 8 CD Player
Open Questions:
363 people viewed this question
 Grubhead
Grubhead
