Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp Z-830 light blinking H 4
  • jliu Nov 23, 2007
    lignt blinking U 2
  • 208 Answers
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 07, 2007
  • 4 Answers
H4 can occur when the copier is turned on in area thats below 65 degrees. If the copier does not warm up to the preset temperature fast enough, then a H4 code appears and disables the copier until its reset using code 14 while in the diagnostics mode. The older Sharp copiers used this sequence of pushing these following keys. "C, "0", "0," "C" to get into diagnostics. When done correctly the machine will flash a "1" in the display window, and by typing in 14 and then pushing the green print key it will reset the code and the machine will immediatley begin running and retry warming up again. Also Sharp used "C', "interupt, "0", interupt. It always took 4 keys to get into the diagnostic mode, with 14 restting the codes. .
Posted on Dec 01, 2007
  • Sharp Master
  • 1,113 Answers
H4 indicates fuser not reaching temp, heater lamp, thermal fuse or thermister stuffed all parts of the fuser, you will need to have fuser replaces, not a operator repair job call a tec
Posted on Nov 21, 2007
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
All three lights are blinking on the 4 wheel drive selector on my Chevy S10 4 wheel drive pickup
you will know if you are in 4wd if you take it on a dry road. you will feel it fighting you when you turn sharp.. as for the blinking lights . that's your truck saying..........please take me in for some servise
Dec 02, 2013 | 1991 Chevrolet S-10 Blazer
So when i turn on my sharp hd it turns off then the opc light comes on! Then the power light and opc light keep flashing!! Alls i want 4 it to work? Plz help
The television has gone into a coma. It is going to need to be serviced or replaced. The blinking code is a pattern. If you look at the power light and the opc light separately and independently, you can acquire the blinking pattern. Cover opc and look at power only. Note how many times it is blinking before it pauses. It might just blink steadily. Next cover power and look at opc alone. Note how many times it blinks before it pauses.
Depending on which model you have it might work if you leave the television unplugged overnight. The next day plug the television back in and wait for the blinking to start. Hold down the power button on the side of the television until the light stops blinking and turns red (usually right away). Let go. Press and release the power button once more and the light should turn orangish and then green. The television should turn on.
You can call Sharp and have a case file created and try and INIT with the customer service representative.
Mar 07, 2011 | Sharp Televison & Video
Sharp LC-26D43U TV. After power is turned on the power light comes on for a couple of seconds and then there is a click and the power light blinks 4 times then pauses and repeats the 4 blink sequence......
Power board is detecting an 'over-or-under-voltage' condition from other circuits. Could also be high dc volt shut-down. In either case, the tv is in protection mode to stop further damage this is why it flash an error code 4 times. Each number flash intervals tells the tv-technician what area the fault may potentially be. take it back if its under warranty, or have a repair shop near you fix it.
Nov 20, 2009 | Sharp LC-26D43U Television
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Jul 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Blinking light
H4 is a fuser error, check the continuity of the fuser lamp.
Aug 27, 2007 | Sharp AL-1217 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
519 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
