Question about Yamaha Music
PSR-2100 need to find replacement circuit board.
Yamaha PSR-2100 The keyboard was dropped by cargo while in a flight. The corner where the modulation and pitch and the headphone socket is was broken. I opened it and saw the circuit card broken in half. There is no sound but all other function are working.
Yes if u can't find the board u r looking for ,u can jump the cable if u have the diagram for the cable alignment
Posted on Jul 18, 2013
  • 4,234 Answers
I don't have a parts source for these other than Yamaha. Call them up to get the part number for the board. The sound is usually sent through the headphone jack which acts as a switch when you use headphones. Replacing that board should resolve your problem. If the board is no longer available, it is possible to repair the existing one, but this is a specialty task and not one I would recommend a novice attempt.
Please keep us posted on your progress,
Dan
Posted on Jul 25, 2009
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Dgx 230 dc in connector bad
This type of keyboard is well know for the power socket breaking away from the main PCB. You will need to unscrew lots of screws to reveal the circuit board with the power socket on. If you look closely at the solder side you will probably see that the track that the socket is soldered to has broken. Simply link the solder joint to the circuit further along the track by bridging between socket and next point along the track. You may need to replace the socket if it has become damaged. If you can use a soldering iron it is fairly easy but if in doubt contact a repairer.
If you need a socket Google :
Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
Jan 25, 2013 | Yamaha Keyboard w/ 76 Graded Action Piano...
Finding yamaha psr 450 circuit board with part #28750 DM X7588
The actual part # is WC35550R but is costly! $400.00 from Yamaha.
Nov 14, 2012 | Music
Am looking for a power supply board for yamaha keyboard
Normally if the board is there, I repair failed components. If the board is missing, call Yamaha America parts dept. They MAY have the part you need. That will be the only source of a complete replacement. Power supply boards are usually easily repaired.
Mar 04, 2011 | Yamaha PSR-295MS Portable 61-Key...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Looking for a replacement volume control module for psr e303
You can obtain these from Yamaha Music Spares Dept in your country.
Go to the following Yamaha site link and choose your country
http://www.yamaha.com/
Select Musical Instruments - Support and the contact details will be displayed.
I just used them to by some parts for a Clavinova and they were in stock, accepted credit cards and delivered within 24 hours.
Oct 18, 2009 | Yamaha Full-Size Keyboard
Getting an error message when starting the PSR 2100
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Sep 18, 2009 | Yamaha Music
Can we connect ipod touch with yamaha psr 2100 keyboard ?...
http://www.yamaha.com/yamahavgn/Documents/KeyboardsDMI/PSR2100E1.pdf
On page 155 it looks like the only input for device(s) in a 1/4" mono jack for microphone or guitar, not stereo that would be needed for iPod. However, if you could set the iPod to mono output, this 1/4" input would work for you.
Aug 09, 2009 | Yamaha Music
Yamaha PSR 75
You have to completely remove the circuit boards. If this is the keyboard I'm thinking of then the keys are all mounted on the same part like parts on the sprue in a model airplane kit. If its a different one then you have to remove the assembly and take the spring of the key you want and at the other end when you flip it over there is a strip glued on the metal frame to secure the keys that you have to peel off for that sector.
Jul 09, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Open Questions:
Music Logo
591 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
