Question about Toshiba e-Studio162D Copier
Problem is it says SYSTEM ERROR EOO7 - Toshiba e-Studio162D Copier
  • 313 Answers
Check for a paper jam at the registration thats the area just before the drum unit it could be a small piece stuck or the sensor jammmed..Good Luck A
Posted on Jul 31, 2009
Canon iR2018N showing system error E007
eoo7 - fixing film in fixing unit does not work or spin, the cause of dry lubricant or fixing film torn, or white sign has been worn.
if dry then put lubricant again, if you tear you should replace it with new one, after that you must clear error. goodluck
pic of fixing film
Feb 22, 2015 | Canon iR2018N
Service manual
The fuser has a problem. The error refers to affixing film displacement error. The mylar sleeve over the heating element in the fuser has probably shredded and needs to be replaced.
Sep 02, 2014 | Canon iR 2016i Black and White Copier
Eoo7
Fixing film rotation error
Dec 30, 2010 | Canon IR1018J Black and White Copier
How can i solve this errorcord eoo7 canon IR2016J
1. Check fixing film sensor.
2. Check fixing film sensor connector.
3. Check fixing film.
Apr 16, 2010 | Canon PC-940 Black and White Copier
Eoo7
did you try a hard reset? if not please try that and get abck to us
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Eoo7 on ir2016 how to solve the problem
hi
you need to replace fixing film there is no way to make remedy?because the edge of the film is not in proper position
Dec 13, 2008 | Canon imageRUNNER 5000 Copier
Canon c122 copier code EO 07
EOO7 error means: fusing film damaged or out of position. This means that an error has occurred with the fixing unit. This is the hot bit the paper goes through just before it comes out of the machine. It consists of a lower roller and above that a thin loop film of thermal plastic with a ceramic heater inside it. It is almost certain that this film has become displaced or damaged. E007 means that this film is not rotating correctly or jogging back and forth over the sensor. It will need a new fixing film. Did you run the adjustment for installing a new fuser film when you installed the fuser? Other than that, just check to make sure the film isn't broken or missing a piece.
May 03, 2008 | Office Equipment & Supplies
Copier problems
What model gestetner is it? There are different ways to rest it. What generation are you talking about? 10 years old or two days old model?? Need some more info. The problem may just needs to be rest, it most likely a fuser code to cold or to hot.
Mar 10, 2008 | Office Equipment & Supplies
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
Toshiba e-Studio162D Copier Logo
148 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
pkwc
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
