Question about Acer AL1932D 19 in. Flat Panel LCD Monitor
Monitor switches to standby when I attempt a connection
I have tested connecting through the computer via the screen cable and the S-Video out - the monitor says AV1 then prompts with 'No Signal Output' and switches back into standby mode.
A friend says it is the capacitor, another says it's a graphics card issue. If it is the capacitor how do I replace it?
The model is the ACER al1932
    President:
  • 1,383 Answers
When you power up the computer check NUMLOCK Led on key bord if it is on and off when you pressnum lock then your cpu gives dispaly to monitor correctly.
But if not then refix RAM memory in cpu.
then when you power up the computer press F8 key then enter in enable vga mode then go to control panel ->dispaly ->settings then change screen resolution to 1024 *768
then resstart but if problem still then you neeed to repair your monitor .
Posted on Jul 24, 2009
  • 116 Answers
Guide on how to change capacitor.
Samsung syncmaster sa350 start computer up then in the top left corner it shows a graphic that says hdmi, then the computer screen goes blank and the power button just blinks red continueously with a blank...
Is your computer connected via the HDMI cable? If not pull up menu and change to another input type. If it is HDMI, check cable ends. You can test by plugging into a Blue ray player and see if video plays on monitor as a test method to verify video coming from computer incase your video card has died for some reason..
Your monitor is going into sleep mode since it can not see an HDMI signal coming across the input. Check your cable though.. sounds like the biggest culprit to me.
Jan 29, 2014 | Smart Modular SV3170A
I have a NEC PlasmaSync 42MP02. When I turn it on, there's a click the standby LED changes from red to green, but then goes back to red again. Nothing appears on the screen, it remains dark.
Monitor is not receiving the video signal. Check the video connection cable at the back, also test the monitor on a different computer.
Jul 05, 2008 | NEC Televison & Video
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
Screen stays black, you can still hear it snapping pics
Manaual says:
Standby mode for saving power: press the shutter-release button halfway.
Camera and computer are connected via the USB cable.
Camera and TV are connected via audio/video cable or HDMI cable.
Adjust monitor brightness.
When the internal temperature of the camera is high, the monitor darkens to reduce heat generation. When internal temperature cools, the monitor brightens again.
When the power-on lamp is covered after the camera has automatically increased monitor brightness, the monitor may darken.
If you did not drop teh camera, or cracked it in your backpocket, perhaps you also chould check the battery. If it is charged, and still has enough capacity.
Nov 05, 2013 | Nikon Coolpix S100 16.0 Megapixel, 5x...
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
No display, light goes green but on screen says no connection then goes yellow for standby tried both DVI and VGA so now linked my pc to my tele via DVI to HDMI and works fine anyone know what this could...
here is the simple test to detect hardware malfunction.
on every monitor these days whether its CRT or LCD already programmed inside self test.
detach your cable data to CPU and power on your monitor. if its displayed self test on your screen mean its OK and something wrong with your CPU, could be VGA error.
if its just black display mean some is wrong with your monitor.
if you post more detail maybe we in FIXYA could help.
thanks.
Mar 11, 2011 | Hannspree HW191D LCD Monitor
When I power on my computer my monitor screen goes a solid whitish gray. worked fine yesterday, and then today nothing.
Laptop LCD screen turned completely white
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
Feb 01, 2010 | Computers & Internet
Dual Screens with a VGA connection
The easiest way would be to purchase a video card that has 2 vga ports on it, allowing dual monitor support. Here is an example.
http://www.amazon.com/Matrox-G450-16MB-Dual-Video/dp/B00194CT5A
Dec 29, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Acer AL1932D 19 in. Flat Panel LCD Monitor Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
