Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
How do i remove the cluth drun on a husqvarna 455 rancher
    Problem Solver:
  • 13 Answers
Hi, first take off the clutch cover by removing the two bar nuts.
The nut on the clutch is left hand thread. You need to have some sort of piston stop to bind the engine when you remove the nut. They make tools just for that( it's called a piston stop) but I like using a small piece of rope. Just take out the spark plug, run a bit of the rope down in the cylinder and that will hold the piston really well. You could use a lof of things for that, I would be careful that it's something that won't gouge or mess up the top of the piston though. When you have that done you can remove the nut holding the clutch assembly on and remove the drum. ( REMEMBER that left hand thread ) Hope that helps you.
Posted on Jul 24, 2009
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
How do I take the muffler off a rancher 455 husqvarna chain saw?
two 6mm screws sunk down inside the muffler, use a 5mm allen key to remove
Dec 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Will not crank,low compression husqvarna 455 rancher
How you cnow its low pressure? check spark, air filter, and any air leak from between cilinder and carburator.
Oct 14, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 455 rancher. the chain brake is locked! how can i fix this?
Remove the side cover to access the brake. Look for bent or broken components or maybe just sawdust is blocking the action. Good luck!
Jun 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What is the recomended gas mixture for my 455 rancher husqvarna
All Husqvarna products for at least the 5 years are 50:1. As are every manufacturer with the exception of Poulan which is 40:1. If you are going to provide advice PLEASE take a few minutes to ensure it is correct! HTH
Lou
Feb 07, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
527 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
