Question about Epson Stylus DX6050 All-In-One InkJet Printer
Installed a refubished Epson DX6050 and just get 3 cogs and E90
Help!!!!
    President:
  • 627 Answers
Try this reset utility
Posted on Jul 24, 2009
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Epson Stylus Photo PX800FW paper jam
    Got my own PX800FW.
    Please note that ADF paper jam online docs of EPSON Aculaser 1100 http://www.epson.co.uk/gb/en/viewcon/corporatesite/products/mainunits/faq/2929/1393#toc6 are craph* more detailed than the PX800FW **** that EPSON is making users put up with.
    I am having the very same ADF scanner jam issue (paper stuck directly when trying to feed into the lower rolls).
    Initially I suspected the upper paper feed rolls (turning them requires rather strong force), but they were not the actual problem (see below).
    If you want to inspect these top rolls, then remove the top flap
    (use a screw driver to somewhat (and obviously carefully!) bend the plastic hold located towards the user panel side, then lift off top flap.
    I then unscrewed its 4 screws.
    To remove the main roller mechanism, you need to pull out (somewhat forcefully, but obviously carefully) the large white extended cog bar. Then push out the somewhat larger wheel bar from its flap-side plastic holder.
    Now you\'re able to (while keeping a watch on the small white tab that\'s being drawn back by a spring) remove the entire roller skeleton.
    I then proceeded with removing the end cap (fiddling with a screw driver - but watch out for some parts getting lost due to a somewhat strong spring!) and replaced the spring with a weaker one, and adding some washer plates reinforce the slightly weakish spring. I then ended up with a roller mechanism that was almost as strongly pressing the rolls towards paper, yet actually turning them ended up easier on the motor.
    I then put everything back together, but an attempt with the newly replaced parts failed, too.
    Then I directed my attention towards the main motor / cog mechanism.
    I rather instantly had to discover that the main cog at the main ADF motor was broken, and this is very likely to be the reason for the ADF jam issue.
    This rather flimsy black cog is made of plastic (and having some nice tiny predetermined breaking point holes to boot!! guess where it did break...) and sitting on a metal drum which seems to be rather strongly attached to the main motor axis, unfortunately.
    I will now try to remove the drum, possibly with the help of hopefully successfully warming it via a hair dryer. Choosing to glue the original plastic cog instead doesn\'t sound like such a marvelous proposition...
    Given the rather flimsy appearance of the entire printer a future EPSON choice is quite unlikely.
    Oct 23, 2012 | Computers & Internet
    EPSON PM210 ERROR CODE E90
    epson pm210 error E-90 how can slove
    Dec 23, 2010 | Computers & Internet
    I have an Epson Stylus photo R245 and have got error code E-90 with 3 cogs showing on display
    epson stylus photo r245 fault E-90 WITH 3 COGS
    HOW DO I RECTIFY THIS PROBLEM
    Aug 16, 2010 | Epson Office Equipment & Supplies
    How can I fix my E90 error on my Epson Stylus DX6050/
    this may occur on your connection, try to clean the cable or even check the port where you plug the power cord and your usb. clean it then replug it back.
    Oct 12, 2009 | Epson Stylus DX6050 All-In-One InkJet...
    E-90 error message on the printer
    Hey Pretty Joy,
    I had the same error and looked at the suggestions. It seems all of the user correctable problems are related to the ink carriage not being able to move freely (mine was a paper jam). Open the lid and see if the carriage will move,
    May 05, 2008 | Epson Stylus CX6000 All-In-One InkJet...
    Error message
    I found this solution in the web and it worked!
    The slider on the left hand side (i think) of the machine has slipped. Remove the cover, and you will see a large white cog with a white vertical slider behind it. On each you will see a small arrow. You have to remove the cog and line up the 2 arrows on the cog and slider and then reinstall the cog. This should solve the issue.
    The left hand panel of the laser printer was a bit tricky to get up but a bit of perseverance. Then remove the white cog by releasing the two tabs round the center metal pin. You need to align the vertical slider's pointed end with the horizontal slider's arrow precisely as even slight misalignment will not fix it. Then fixed!
    Jan 01, 2008 | Epson AcuLaser C3000 Printer
    Printing problem
    Since the printer is a top feeder, meaning it feeds the paper from the top your printer is defective. Just call the company up and they'll send a refubished one. This happened to my Lexmark Printer then it also went in sideways hoe this helps. They told me to clean the wheels inside or turn it upside down and tap it a few times because it could have collected dust! Sorry if i didn't help!
    Dec 13, 2007 | Epson C64 InkJet Printer
    Epson Stylus DX6050 All-In-One InkJet Printer Logo
    980 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
