Question about Epson Compatible Inkjet Cartridges 10-Pack Combo for Stylus Photo 700, EX, and PM Series Print... Printer
Problem in printing
The specified printer has lost its connection to the server.
  • 164 Answers
Uninstall and reinstall the printer
Posted on Jul 24, 2009
How to specify a host name for jetdirect 170x
Connect the print server to the router with an ethernet cable and connect the server to the printer. Find the IP address for the printer/server by pushing the "test" button on the print server. The IP address will be listed on the paper printed during the test.
Nov 12, 2013 | HP Jetdirect 170x Print Server
How to make a printer wireless
Plug into a wireless print server.If your printer has a USB port, you can plug in a wireless print server, a small box into which you can connect your printer. The advantage of investing in a print server is that you don't have to connect the printer to a PC, which means you can use your laptop and print anywhere in your home.
.tmnAdsenseContainer{margin-bottom:10px;} We found plenty of print servers in the $50 range on Newegg.com, although many of the models cost closer to $75 or $100). Before you buy, make sure the print server is compatible with your printer (the printer's written materials are less likely to specify compatibility with print servers).
During the setup, you will have to plug the printer into the printer server, and connect that to the router using an Ethernet cable. Meanwhile, you'll have to install software on your computer and configure the connection, as you would when setting up a router.
also try this link will help you
http://www.makeuseof.com/tag/printer-wireless/http://www.ehow.com/how_4530941_make-printer-wireless.html
http://www.labnol.org/gadgets/make-wired-printer-wireless/12639/
Dec 27, 2012 | Samsung Office Equipment & Supplies
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
Operation could not be completed. enter the printer name was incorrectly, or the specified printer has losts it is connection to the server. for more information click help
  1. Are u on an office / home, NETWORK?
  2. Is the printer connected directly to your PC? or
  3. Is the printer connected to a router?
  4. How is the printer connected Wired / Wi-Fi?
  5. Have u been able to print on this printer before?
  6. When was the last successful print taken?
  7. Any new Antivirus Installed?
Sorry bout so many questions, just makes it easier to answer than going in circles later on
Cheers Eddie
Nov 13, 2010 | Microsoft Computers & Internet
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
When Verizon installed a new a new service I lost computer-printer communication. Do you have updated software to re install the print server again? Thank you for your help
you need to reinstall you print server
following is steps to reinstall print server
1. connect printer to print server with USB cable
2.print server to computer with CAT5 cable
3.put the CD (which you got along with print server) in computer
4.follow instruction step by step
5.It will asked you for IP address, you need to assign IP which is withen the range of your verizon modem(for example 192.168.0.50
after that it going to work
regards
prakash
Feb 12, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
Connect through ethernet connection
The only thing you can do is connect it to your new network''s router....from that point you would have to install the printer, and specify the IP address of the printer, then you will be able to print. Actually, every computer on your network will be able to print from it.
If that is something you want to do, let me know and I can give you a step by step for configuring your computer to print to that copier.
Feb 25, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Shared printing problem
Go to Control panel open printers and faxes delete the existing printer, re install it by clicking the add printer, browse the path to your boss machine, when you find the printer auto install it.
Dec 18, 2008 | HP Business Inkjet 1000 Printer
I cannot print using DP-G310 print server connected via switch to the HP Laser Jet P1005 printer.All the configurations are ok ,but i still wonder what is happenning.When i connect the printer direct to...
Sorry but P1005 does not come with its own processor to work of a Print Server, it needs PCs processor to process the printed file and send it in a specified format to it. This makes it cheaper for HP to make printers and sell at a margin because their is no processor in them. You have to get a printer which has a processor to work with a Print Server for instance look for Hp 1300 or HP 1100 series
IAK
Nov 11, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Lost Connection after 1 print-job
Please check the print queue in the computer. Clear it. Then restart the printer and the print server. See what happens...
Oct 24, 2007 | U.S. Robotics USR7500A Print Server
Open Questions:
See all Epson Compatible Inkjet Cartridges 10-Pack Combo Questions
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
