Question about Toshiba 42H81 42" Rear Projection Television
There is blue yellow color blur on the screen with cable or dvd
The TV suddenly starting showing a double image on the screen with a blue-yellow-green color blur. Do I need to get a new TV.
  • 586 Answers
This problem is of "CONVERGENCE". You have to replace the convergence IC's which is better to buy a new one TV, Just contact any expert and replace the convergence IC's and your TV work fine again you need not to buy a new TV.
Thanks for using fixya.
Posted on Jul 24, 2009
The screen shows a green/ orange screen, even when we play a DVD... How can we make that go away?
How is the player connected to the TV? It could be S-Video, HDMI, RCA, or Component Video cables. My guess is that you're using component video cables. There will be three wires that carry the video signal to the TV, and each wire carries one color. There will be a blue, yellow, and green cables. If one of these cables is not seated properly, it can cause only one or two of the three color signals to make it to the TV, causing the image to be discolored. You should check the connections of the cables. You'll also see the sound cables, probably red and white. Do not get the red video and the red sound cable mixed up!
Jan 16, 2011 | Philips DVP3982 DVD Player
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Apr 26, 2017 | Hitachi 61SWX10B 61" Rear Projection...
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Connecting panasonic dvd to olevia tv
when connecting a dvd player you want to try using the yellow red and white cables.. ( AV CABLES) to the television.. just match the same color on the back of the television. Once that is done change the source on your remote until it displays composite then the image should be on.
if you will like a better image quality use the component cables (green, red and blue cables) but the dvd player has to have does colors as well or else it wont work.
Mar 21, 2009 | Panasonic DVD-RV30 DVD Player
Change in color, computer problem inside TV
For "thechances", The LVDS cable has gone bad. This cable connect between the mainboard and the panel. The replace the cable will fix the problem.
Feb 17, 2009 | Vizio L32 32 in. LCD HDTV
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
May 23, 2008 | Audio Players & Recorders
Toshiba 42H81 42" Rear Projection Television Logo
238 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
