Question about Canon PIXMA MP150 All-In-One InkJet Printer
How to solve the printer mp145 the ink absorber is full?
    President:
  • 627 Answers
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power.
Posted on Jul 24, 2009
  • evolgbody Mar 08, 2011
    after i pressed 4 times, what will happen?
    coz my printer keeps showing zero
    what next?
    President:
  • 2,923 Answers
Reset the printer. Check the link below and it would give you instructions on how to reset it:
http://slayo.com/resetting-printer-canon-mp145-and-canon-mp160.html
Hope this helps and have a great day!
SOURCE: waste ink absorber full
my printer is very broken in this so absorber full,it make reset manual,can helm me
Posted on Feb 22, 2009
jay767
  • 386 Answers
SOURCE: My Canon printer PIXMA MP145 ink absorber is full.
Hi Good day!!!
Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. You will probably need a flashlight to see the pads. They each sit in a rubber retainer. The pads can be removed very easily and cleaned. Take the pads out of the retainers with tweezers. They clean up nicely with warm water but you can use something like Simple Green if they are stubborn. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running faucet will do the trick. If there is ink in the rubber retainer after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the retainers and you have successfully cleaned the ink absorbers. Now you may have to reset the error message so you can get back to printing. This is how to do it.
Following is the procedure to reset the waste ink counter for the Canon Pixma MP150
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again.
Don't forget to vote thanks!!!
Posted on Oct 30, 2010
Rider On Way
  • 1679 Answers
SOURCE: Cannon mp145 ink absorber full,
Follow the steps below to fix the problem.
1. Turn off the printer (power cable is plugged), press and hold the STOP / RESET then press the ON / OFF
2. Hold the ON / OFF, press the STOP / RESET 2x
3. Release both buttons, wait a minute, and the printer will enter SERVICE MODE
4. The printer will be charging
5. After the printer has finished charging, press the STOP / RESET 4x. (Waste ink counter reset)
6. Each time the STOP / RESET button, light ON / OFF will turn green and orange colors
7. After that Turn the printer off by pressing the ON / OFF (3 times for printers die total) and unplug the POWER
8. Turn the printer back.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Posted on May 13, 2011
SOURCE: ink absorber full
I disagree with the advice at printerhelp.me.uk. It is not simple to clean out the ink absorber, but it is certainly possible. First, disassemble the printer, 3fb11e6.jpg then remove and squeeze out the pads of the approx 60 ml (1/4 cup) of condensed ink therein, then rinse them out with water and allow them to dry. Later, reassemble printer and perform a reset as per other articles on this site and others, or use downloadable resetting tool.
As others have pointed out, Canon and other companies are doing a service to us through the error message. If we don't clean the pads, eventually the ink would overflow and leak onto our desks. However, that would probably require 150% of the actual time or ink flow that they have used to activate the alarm.
Posted on Nov 17, 2007
SOURCE: Waste Ink Absorber is full In Canon Pixma IP3300
please give me resetting soft for canon Pixma iP 3300 printer.
Posted on Oct 06, 2008
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
How to fix error 24 for mp 160????
Hi
This is a purge unit error hence you need to check and make sure the purge unit is working fine. If not you need to clean it.
THE PURGE UNIT IS THE ONE ON THE RIGHT SIDE WHERE THE CARTREIDGE RESTS WHEN YOU TURN OFF THE PRINTER.
And at the same keep the below mentioned error list for your future use.
CANON MP140, MP145, MP150, MP160 ERROR CODES RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E3-3 = Paper jam
E4 = No ink
Direct Printing
E29 = EEPROM error
Jul 31, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Im using canon mp145 printer.i have problem when i want to print out.the erroe was the ink absorber is full.how can i solve this problem?
The only way to correctly repair this fault is to service the machine
waste absorber pad needs to be replaced.
the waste absorber counters need to be reset
Feb 15, 2011 | Office Equipment & Supplies
Absorber is full canon mp145
All ink printers clean the printhead periodically by squirting ink through the nozzles, and collecting it in a sponge type area in the bottom of the unit. In the Canon ink printer, this absorber is monitored, and when it becomes full, it gives you the full message. The printer stops to prevent ink from leaking out of it. (HP has no monitoring system, you know you need service when your desk is ruined)
To replace the ink absorbers on this model, it requires that the printer be dismantled, and a good tech will wash everything, replace the absorbers, and reset the counter.
You have a low end model that can be replaced for what it would cost to do this job.
I don't think it's a job for the do-it-yourselfer.
Sep 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber is full canon MP145 what is the solution in this problem
ink absorber is full! how to reset this error (E 7 2) - canon pixma mp145.
Dec 27, 2009 | Canon PIXMA MP150 All-In-One InkJet...
The ink absorber is full
plese it is problem your printer is not print because some of ink is full printer wast tank clean it and reset press printer resum button two times
if you are not success then you go to in your area service authorised delar
Aug 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP145 Ink Absorber Full Problem.
I got on error message when started to print.
It’s kept happened and message dialog box “The ink absorber is full” occurred.
Mine is Canon MP145.
Can somebody please help me , on how to fix this problem !
tq
Jan 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Mp 145
How to reset the e27 for canon mp145 printer?
May 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
3,263 people viewed this question
old marine
old marine
