Question about AMD CPU Cooler Fan + Heatsink for up to 2800+ CPU Heatsink & Fan
My AMD X 2 4000+ Windsor is overheatting
I just bought it and it gets around 90 degrees Celsius without doing anything.
I use the BOX cooler from AMD and the mainboad is Gigabyte MF3 with NFORCE3 chipset.
  • 309 Answers
Re: My AMD X 2 4000+ Windsor is overheatting
Hi, you shouldnt even switch on the PC if its running at that temperature, machine will be restarting and shutting down on you.
If you just bought it, you should take it back to the shop.
Otherwise you need to remove the old heatsink and fan and apply new thermal paste to the cpu and resit the heatsink, if its still running very hot over 50c you will probably find the cpu has been damaged.
Have a nice christmas
Posted on Dec 13, 2007
0 characters
3 Points
Overheats, what cooler would be the best
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line dust causes static to build up in a computer causing it to overheat any many other problems then you could get a usb 3 fan laptop cooler pad this will keep your laptop very cool
hope this helps
Mar 24, 2011 | Compaq Presario Laptop Cooler
My cooler for my laptop wont work. it over heats and makes my laptop over heat also.
make sure the cooler fan is getting power test the leads that attach to the cooler make sure the connection is good and not faulty
also you should clean the cpu make sure there is no dust built up on the fins of the cpu
(dust will cause static) to computer overheat and lots of unforseen problems
also you purchase a portable usb laptop cooler pad
hope this helps
Mar 06, 2011 | Rocketfish Universal CPU Cooler RFUCPUCF...
I have intel cooling fan this is doing very sound . what i do?
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
Take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loos
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Hope this gives you the information you need
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through fixYa.
Thank you
Dec 07, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Cpu overheat
Check the heat sink .
Oct 21, 2009 | Computer System Cooling
Hello i just wanted to ask you guys something: i have a e8400 stock @ 3ghz and when i play games like crysis it seas that it's heated up to 45-48 degrees celsius and when i'm not playing any games i have...
the better the cooling you can add to the processor the cooler and better your cpu will be. the 140mm fan is a case fan, yes?
you will need to upgrade your cpu fan and heatsink.
CPUs on 45nm core are overall cooler than their predecessors on Core micro-architecture. However, the temperature different under 100% workload makes only 4-5 degrees. The thing is that Wolfdale processor core is smaller and features higher transistor density within a semiconductor die, which makes it a little harder for the heat flow to dissipate properly. That is why Wolfdale and Conroe heat up almost identically in idle mode. As for the relatively low temperature of AMD Athlon 64 X2 6400+, with twice as high TDP as that of Core 2 Duo actually, it can be explained by the not very best location of the on-die thermal sensor that is situated quite far from the hottest spots of the processor’s semiconductor die.
Mar 01, 2009 | FMI CPU Sensor Alarm Temperature...
How to remove clipon fan from heatsink (fin part) it's stuck
Are you sure it is stuck on
The fan on my AMD has 4 small clips holding it on. You really have to look for them
Oct 20, 2008 | AMD Cooler Master: Cooler Master...
Sony TZ240n problem.
If less than 90 days, it is under Sony's full coverage. Usually the fan runs intermitantly. Check that air paths are not restricted.
Aug 01, 2008 | Sony CPU FAN CPU Fan
Pc problems
Hi - what Wattage is the Power Supply? I think you may need around 500 watts or more.
I have had similar problems in the past caused by insufficient Power being supplied to components (including having to move my Video Card's power cable pick up to very close to the Power Supply Unit instead of coming off the tail end of the wiring harness! - this worked in my case).
Hope this helps.
May 12, 2008 | Computer System Cooling
AMD CPU Cooler Fan + Heatsink for up to 2800+ CPU Heatsink & Fan Logo
95 people viewed this question
Top AMD Computer System Cooling Experts
Brian Sullivan
Brian Sullivan
Are you an AMD Computer System Cooling Expert? Answer questions, earn points and help others
