Question about HP (J8131A)
Hi,,, i have problem with hp j8131a access point i cant enable the new SSID,,, as i tick the enable button... the tick dissappear after i refresh the page.
  • 1 more comment
  • Abdulfattah Safa Jul 24, 2009
    thank you for your help.... but it didn't work.. i sent you a mail with more details.
    waiting your answer.
    regards
    i did it many times.... with nothing new
    thank you
  • ted1430
    ted1430 May 11, 2010
    How many SSIDs do you have? Max is eight for this unit. Which enable checkbox are you talking about? There are only two in the SSID screen that I can think of and neither should show this behavior. One is for Spectralink and the other is for tagging VLAN packets which you'll probably need if it's an additional SSID.
    President:
  • 1,383 Answers
After enabling button for ssid you have save settings .Save option is in system menu thensave settings then it automatic restart and take effect.
Thanks for using fixya.
Please rate this solution if it helps.
Posted on Jul 24, 2009
  • 2 more comments
  • kishor
    kishor Jul 24, 2009
    Reset your router .
    You can reset your router with reset button it is in back side of router press it for 15 minutes then all settings are reset to defaults.
    Then you can enable your ssid.
    Thaknks for using fixya.
    Please rate my solution if you think that i helpfull to you.
    Many Thanks .
  • kishor
    kishor Jul 24, 2009
    Reset your router .
    Many Thanks .
  • kishor
    kishor Jul 25, 2009
    then you need to change your router it has some hardware issue .
  • kishor
    kishor Jul 25, 2009
    sir please rate my solution.
    Thanks
I just got a ps3 and i cant get i on line it says wrong ssid how do i check this
Improve the Fixya.com experience for everyone by voting!
The SSID (Service Set IDentifier) is a token which identifies a 802.11 (Wi-Fi) network. The SSID is a key which is set by the wireless network administrator. You must know the SSID to connect to a 802.11 wireless network. However, the SSID can be discovered by network sniffing/scanning. By default, the SSID is part of the packet header for every packet sent over the WLAN.
SSID access points continuously broadcast radio signals which are received by client machines if enabled. Based on the automatic or manual configuration, the client can connect to the access point. A SSID is generally 32 bit long, but when displayed to the user, it is projected into a human readable ASCII format. Multiple access points can possibly share same SSID if they are for the same wireless network. Many wireless access points support broadcasting multiple SSIDs, permitting the formation of Virtual Access Points. Such Virtual Access Points partition a single physical access point into many logical access points, each of which can have a special set of security and network settings.
SSID Security Issues
Every user of the network must configure the SSID into their system. If the network administrator seeks to lock a user out of the network, the administrator must change the SSID of the network, which will require reconfiguration of the SSID on every network node. Some 802.11 NICs allow you to configure several SSIDs at one time.
ssid example SSID
Default SSID's
Most 802.11 access point vendors allow the use of an SSID of "any" to enable an 802.11 NIC to connect to any 802.11 network. This is known to work with wireless equipment from Buffalo Technologies, Cisco, D-Link, Enterasys, Intermec, Lucent, and Proxim. Other default SSID's include "tsunami", "101", "RoamAbout Default Network Name", "Default SSID", and "Compaq".
Every time a client connects to the wireless network, the SSID is communicated in plain text format, which can easily be sniffed by eavesdropper using sniffing applications like Kismet. Hence, additional security techniques are required to be implemented in order to enhance the wireless security.
All the best
Ben
Jul 03, 2011 | Arris SURFboard SBG900 Wireless Router...
When I connect my modem dorectly to my pc it works fine with IP address 192.168.1.33. When I go through My D100 I have no connection anf the IP has changed to 192.168.0.100 If I reinstall on dynamic IP...
I think a functional explanation may be of some assistance to you.
The IP address is assigned to the server or client software, but not to the physical workstation which the software or device is installed.
D-Link and virtually every other provider uses IP addresses from a Private IP Address class, which is special class of IP addresses that is reserved for private local networks (not to be confused with Virtual Private Networks, or VPN).
The default IP address is 192.168.0.x and assigned automatically. The most common IP address in any local system is 192.168.0.1.
Over the years, I've found that it is unnecessary to manually TCP?IP settings unless the automatic settings or configuaration has failed When I do have to change the settings, the following are used on Local Area Networks (LANs):
IP Address 192.168.0.1
Subnet mask 255.255.255.0
DNS Do not change
Gateway IP
Address None because the default should be 192.168.1.0 or whatever was
automatically assigned.
Some additional information that should assist you in better understanding a LAN.
SSID access points continuously broadcast radio signals which are received by client machines if enabled. Based on the automatic or manual configuration, the client can connect to the access point. A SSID is generally 32 bit long, but when displayed to the user, it is projected into a human readable ASCII format. Multiple access points can possibly share the same SSID if they are for the same wireless network. Many wireless access points support broadcasting multiple SSIDs, permitting the formation of Virtual Access Points. Such Virtual Access Points partition a single physical access point into many logical access points, each of which can have a special set of security and network settings.
Default SSID's
All the best
Ben
Jun 06, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
I'm trying to connect another computer to my home wireless network. When editing my profile it asks for the Network name (SSID). What's (SSID?
The SSID (Service Set IDentifier) is a token which identifies a 802.11 (Wi-Fi) network. The SSID is a key which is set by the wireless networkmag-glass_10x10.gif administrator. You must know the SSID to connect to a 802.11 wireless network. However, the SSID can be discovered by network sniffing/scanning. By default, the SSID is part of the packet header for every packet sent over the WLAN.
SSID Security Issues Every user of the network must configure the SSID into their system. If the network administrator seeks to lock a user out of the network, the administrator must change the SSID of the network, which will require reconfiguration of the SSID on every network node. Some 802.11 NICs allow you to configure several SSIDs at one time.
Default SSID's Most 802.11 access point vendors allow the use of an SSID of "any" to enable an 802.11 NIC to connect to any 802.11 network. This is known to work with wireless equipment from Buffalo Technologies, Cisco, D-Link, Enterasys, Intermec, Lucent, and Proxim. Other default SSID's include "tsunami", "101", "RoamAbout Default Network Name", "Default SSID", and "Compaq".
All the best
Ben
Jun 06, 2011 | Computers & Internet
Cant use netbook cant find router network but can log on with main computer
- Go to router page - http://192.168.0.1 or http://www.routerlogin.com
- default username and password - "admin" and "password" - (case sensitive)
- Left side click Wireless settings under SETUP.
- then You have Name(SSID) / channel - 11/Mode - b&g/
- then you have Wireless access point
- you have to check the 1st and 2nd option shud be checked.
-- (Enable wireless access point and Enable SSID broadcast.)
- then Security Option - Select 3rd one WPA-Psk - "create password"
-- apply all the settings
--- and then try to connect it wireless.
-- if u can see ur network click on it and try to connect.
-- that will ask u for security key type ur security key there which u have created and then try to connect it.
-- I hope that will resolve ur issue.
If ur issue will resolve please rate this...
Regards
TecKC
Dec 03, 2009 | NetGear DG834G Router
HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
Jun 01, 2009 | HP Office Equipment & Supplies
Router problems
Check with this tip.
Check if router is working on Net using a Lan cable to connect your PCs and check if you can browse from PC..
If Internet OK check if radio is enabled in your Belkin router.
Then check if your SSID broadcast is enabled in your router.
Check if Router and PCI Wlan adapter are on same WLAN standard A,B, G, or N and disable every security protocol (WEP or WPA)
Define a new SSID name and check if you see your Wlan on PC.
Restore your security as soon as connection established.
Jan 05, 2009 | Intel PRO/Wireless 5000 LAN Access Point...
I have a laptop run Vesta trying to set wireless connection to HP Potosmart C4385 print using ad hoc network setup. When selecting Ad Hoc connection in the printer setup it saids it can not find it or...
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Aug 04, 2008 | HP Office Equipment & Supplies
Configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cant get thelaptop to work and very fustrating
u need to first configure teh wire less on the router>go to the main computer>and open browse window and and in teh address bar type- 192.168.0.1 hit enter u can see login screen
user name-- admin lower case or blank
password-- admin lower case or blank or password
and u can see the set up scren and select wire less setup in the left side and follow this
Wireless Settings Wireless Network Name (SSID): Region: --- Select Region --- Africa Asia Australia Canada Europe France Israel Japan Mexico South America United States Channel: 11 Wireless Access Point Enable Wireless Access Point Allow Broadcast of Name (SSID) Wireless Card Access List Security Encryption (WEP) Authentication Type: Automatic Open System Shared Key Encryption Strength: Disable 64bit 128bit Security Encryption (WEP) Key Passphrase: Key 1: Key 2: Key 3: Key 4:
Nov 18, 2007 | NetGear WGR614 Wireless Router
Open Questions:
See all HP (J8131A) Questions
HP (J8131A) Logo
226 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
