Question about Dell OptiPlex 360 Desktop Computer
On using my computer, it works perfectly but after a very long time, it brings a black blank sreen. what could be the cause of this. it is an DELL optiplex 360
  • 374 Answers
several causes can be check,power supply you can check your avr and psu,if you have the power by checking the blower fan of psu and thd fan of processor and indicator led light of your cpu you have the power,you can check your video card by replacing another video card of your pc if still black screen,you can check memory card,if you have multiple video card
pull out one,run again your pc,if still black screen replace by one you pull out try it also.means isolate of checking the device of your computer,you can determine which device is faulty,besure to shut off your pc every time you check the devices,also you can run your pc w/o your hardisk and cd room.replace defective devices so your windows will put back,regards
Posted on Jul 24, 2009
Dell xps touch sreen just blinking blue light but blank screen
Sounds like it went to sleep due to low battery power. May be time for a new battery if it isn't holding charge well.
Plug it into the wall and push the power button once. It may come back on. If not...
Hold the power button down until the machine shuts off completely. If that doesn't work, remove the battery.
Feb 04, 2015 | Dell Computers & Internet
Lap top turns on, but screen blank
Do you get the Dell logo when first turned on? if yes this indicates hard drive trouble, but if there is no logo the problem will be motherboard, first remove one ram memory stick, if no change remove second piece and replace the first, no improvement it is time to have the motherboard assessed.
Jun 13, 2012 | Dell Inspiron 1525 Laptop Jet Black
Windowxp dell 600 lap top will not charge battery or turn on wih ac power do i need a new battery or black sreen does not deytemine ac adapter will not preform best operatings
check first the battery pack... use another batter pack to check the batter if its okay or not... if okay..then use another charger also to check the charger. if the problem is the same you need to open you laptop and check or repair the charger connection or some chips of your unit.
its needed the expert hardware. bring to the nearest computer service center if you can't do it..
Jun 23, 2010 | Dell Latitude D600 Notebook
Forgot password, need to reset
You can reset any user password by logging in using the Administrator account through Safe Mode. In Windows XP Home you cannot log into the Administrator account in normal mode.
When your computer is starting up, hold down the F8 key. This will bring you to a black screen with white text. Use the arrow keys to highlight "Safe Mode" and then hit enter. This will boot the computer into Safe Mode, which will look normal except the resolution will be very low. Log in as the Administrator (should have a blank password). Once logged in, open the Control Panel, then User accounts, then reset the password or whatever user you want. Reboot the machine to get back into normal mode.
Jan 20, 2010 | Dell Microsoft Windows XP Home Edition
MY SREEN GOES BLANK(white) WHEN IM ON IT WINDOWS VISTA
my acer aspire 9300-5349 orbi cam show black screen, how can i fix it..
Nov 10, 2009 | Toshiba Satellite A135-S4527 Notebook
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
ROXIO CREATOR LE DELL EDITION CAME WITH MY COMPUTER AND WORKED PERFECTLY UNTIL SEVERAL MONTHS AGO. I CAN BURN DVD'S, AND I CAN ADD PICTURES TO A DISC WITH PICTURES IF IT SAYS APPENDABLE. WHEN I PUT IN A...
there are alot of kind of cd brand, like, maxwell. princo, ech.... use the common cds or dvd brand. may this cause of cd only. not good quality..otherwise chech your cd room drive. maybe the lins can recognise try to change another cd or dvd room for testing only.. befor you buy or changing totally..
thank you
May 29, 2009 | Roxio Easy Media Creator 8 Deluxe Suite...
My monitor screen goes black
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
May 16, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Black screen
Some USB devices seem to cause this problem. I've had it myself. USB devices when hooked up cause the computer to freeze as it hard for USB drivers to be loaded outside of windows. Try updating you windows thru windows update though even updated I still run into the problem sometimes. If updating dosen't work you need to keep the drive unhooked while booting then hook up in windows.
Dec 11, 2007 | Dell Dimension 8400 PC Desktop
Dell OptiPlex 360 Desktop Computer   Logo
129 people viewed this question
Alun Cox
