Canon me 310...i would like to erase the memory card on this printer because I want to donate it.
SOURCE: memory full on canon fax-tr177
Try unplugging the power cord for 10 seconds. Do you have ink / paper?
SOURCE: i lost my cd to install canon mx310 printer to my computer
Hey,
you can get it from here
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603
Click on drivers and downloads
then select your windows version and download the files
install the printer
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: where is the serial number on canon pixma mx310?
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
SOURCE: need to access fax in memory
lindalacasse --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
SOURCE: On my Canon MX310, the display says
Try this step ... found it on Canon's website
Issue:
ERROR LCD: WAITING FOR REPORT
Solution:
Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX
When
[AUTO PRINT RX] is set to [OFF], incoming received faxes will be
temporarily stored to memory and transaction reports (TX, RX and
Activity) remain in memory. The default setting is [ON], which means
incoming received faxes and transaction reports will automatically
print.
The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
To set AUTO PRINT to ON, please follow these steps.
Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
CAUTION:
When this option is set ON, the fax machine will not monitor the ink
level of the ink cartridges. If ink is low or out, received faxes will
print with streaks or blank. Furthermore, once the fax is printed, it
will be deleted from memory.
