Garden Logo
J
Jim Dahlberg Posted on Apr 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
'97 John Deere 6200: Diamond and (!) light and PTO light flashes dim. PTO switch is OFF. When PTO switch is ON -light goes out. PTO shaft does not turn. Everything else works fine.
jamessizer
Level 3:
  • John Deere Master 7,515 Answers
  • Posted on Apr 04, 2017
jamessizer
John Deere Master
Level 3:
Answers
7515
Questions
0
Helped
690847
Points
37181
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
When I engage PTO or clutch on my 6120 John Deere a flashing warning light beeps and flashes then stops. What's going on?
Not sure about the clutch.
If PTO continues to operate then it's warning that PTO speed exceeded 620 rpm.
If PTO shuts off, then its an operator not in seat detected.
Clutch may also be seat related.
See your owners manual for a comprehensive guide to PTO operation, warnings, etc. Manuals are available, free download in pdf format. See following link.
https://techpubs.deere.com/en-US/Search/Equipment
You might try diag mode and see if any stored codes. See manual.
John deere 6310 pto does not come on but i light keeps flashing even if its disengaged
Flashing pto light is an indication that there is a issue with pto. Low hydraulic fluid or a bad sensor.
John deere 6310 pto not working but i light flashing
There is a bad sensor or problem with pto when flashing its letting you know to have checked out cause there is an issue
8130 John Deere pto code 1883.01
Rear PTO Underspeed. Make sure correct shaft is installed. Restart vehicle and select proper PTO engagement rate in the CommandCenter. If code returns, have your John Deere dealer repair as soon as possible.
OMAR259982 8130 8230 8330 8430 and 8530 Tractors Block File OURX935...
Last website shows to me what appears to be a sensor just to the right of the icon A pointer, identifying the snap ring, in the top right photo. http://manuals.deere.com/omview/OMAR259982_19/gif/RW55322A.gif
Best of luck.
I have a john deere 420 that the pto will not engage. I do have power at the switch
You are going to need to Google John Deere 420 wiring diagram. There is a 30 amp fuse in the PTO power circuit. This provides the power to the Time Delay Control Module which has the solenoid in it. Any chance you can here the slonoid click? There, is a safety interlock switch on the seat. And everything goes to a common ground lug that may be corroded or loose. If the PTO light comes on but dim, then start with the ground. Quite a lot in this circuit.
Dec 14, 2013 • Garden
Jon Deere mower LX277 won't crank
Try replacing the starter solenoid. If that doesn't do it, try replacing the whole starter.
2answers
How do you replace a broken pto shaft in a 1979 2840 john deere
drill into it and use the biggest easy-out you can get your hands on.
Apr 16, 2012 • Garden
11helpful
2answers
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
