Question about Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television
Hitachi Ultravision won't turn on
Yesterday it was working perfectly, we have the "technician" from Time Warner Cable direct us into unpluging one of the cables to correct something that was wrong with their service and now the TV won't go on, the yellow stand by light has been blinking and no image.
2 Suggested Answers
  • 61 Answers
SOURCE: Hitachi 50" Ultravision too much yellow, not much blue
First of all sorry for delay.
can you provide a image of yello shadow.I believe it seems to be technically say "ghost image"
If it is ghost image we can try by entering SERVICE Menu and adjust RGB level of the light engine.
Good luck
Posted on Oct 09, 2008
  • 171 Answers
SOURCE: my Hitachi Ultravision LCD rear projection 62
that is correct you need to replace the optical block to fix this problem the LCD chips are starting to burn out and the it why you are getting this problem reflecting on the screen this parts are around $230.00dlls to $340.00dlls plus the labor it is a thinker good luck I hope this was helpful
Posted on Aug 27, 2010
0 characters
1 Points
Hitachi UltraVision Tv Keeps turning off. The lamp LED blinks. Both light engine and lamp are new.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link
Nov 13, 2013 | Hitachi 50V720 Television
Hitachi ultravision director's series 55"
I don't know how to fix your issue but I have the same tv with a cracked glass front. I would be interested in buying your tv for parts to replace my glass front if you are unable to fix yours. Please let me know. Thanks, Dan
Jun 10, 2011 | Hitachi 55HDX99 55 in. Plasma HDTV
When I turn my hitachi flat screen tv on,
you are not getting a signal change soure ie box or dvd player and input jack then try
Jul 26, 2010 | Hitachi 32HDT20 32 in. Plasma Television
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
I have an older Hitachi 36'' Ultrvision TV. It has worked fine for years up until resently. The problem that I am having is I can not get the direct TV signal to come in. The out from the Direct TV box...
Sounds like you have something in the wrong setting that won't allow the signal to get through. If the video 1 line works OK but regular input will not work, that is almost certainly the problem. I would try just unplugging it (turning it off is not the same thing), let it reset for a few minutes; then plug it back up and see if it will reset by itself. hope this helps.
Jun 11, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Feb 02, 2009 | iLO 3200 32 in. LCD Television
Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television Logo
774 people viewed this question
Top Hitachi Flat Panel Televisions Experts
Are you a Hitachi Flat Panel Television Expert? Answer questions, earn points and help others
