Question about Sony KV-32FV15 32" TV
The HD video input channel has a slanted, dual picture.
I was recently given a Sony TrinitronKV-32FV15, and it works great, except for the HD inputs. When I switch over to Video 4 (The HD channel) The picture is slanted and there are two side by side representations of the screen. Any ideas how to fix this? Thanks!
    Sergeant:
  • 269 Answers
Check for the settings or the inputs doesnt match with the unit.
Posted on Jul 31, 2009
My satellite HD DVR output is connected to the component video input (YPbPr) of a Sony KDF-E55A20 TV. I turned off the TV to change another input (video/l-r) to a different input but I left the HD receiver...
No, that will not damage the input. But if you are using component input and the green wire is off or not connected correctly it will prevent a picture from coming on. The green is the luminance and carries the main picture signal.
Sep 01, 2009 | Sony KDF-E55A20 55 in. LCD Television
Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
Sony KV-32FV15 TY
I have had my Sony KV-32FV15 for about 2 years now and nothing has ever gone wrong(even going through several moves.) I recently moved again and when I plugged in the TV, you can hear the sound perfectly but the screen just stays black. You can not even hear the squeal that the TV makes when comming on. Is there anything that I should initially look at to troubleshoot. I cannot afford at this time the $250 fee to repair my TV. I look forward to your input and hopefully I can get this TV working again.
Oct 24, 2007 | Sony KV-32FV15 32" TV
HDMI input problems
HDMI is suppose to carry sound. With the rest of the symptoms you describe, the first thing I would try is to replace that cable with a good quality one.
Mar 26, 2017 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Sony KV-32FV15 32" TV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
