My hotpoint wf541 wom't drain!!! Ihave cleaned the filter and found some items but it is still not draining... the pump does however seem to be making a humming noise could you please help!!!
  • 850 Answers
Something may have reached the pump & jammed it !
remove hoses to inspect [make sure its not pluged in to power] if it not blocked it may have burnt out the motor b4 you found those items
Posted on Jul 24, 2009
Hotpoint fdw85 does not drain
sounds like the pump is not working
Jun 11, 2017 | Dishwashers
Hotpoint Aquarius wf541 fabric conditioner compartment fills with water and doesn't drain out
There is a syphon tube with a cover dome like a thimble. Lift it off, clean it and clear the syphon tube. Refit the cover.
Apr 25, 2012 | Hotpoint Washing Machines
Wheres the filter on my hotpoint
Hi maizi42,
Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Hotpoint WMA31 Front Load Washer
Hotpoint Aqaurius WML520. No functions at all, motor does not spin, pump does not empty water out, none of the programs work.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 24, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Hi our hotpoint wf541 starts its cycle as normal but doesnt spin and the mini load and reduce crease buttons flash as well as the on/off button, any ideas of how i can fix this thanks.
hi i had the same problem.
its either your filter is blocked or your pump is not working.
after switching the power off, remove the front bottom panel of the machine and unscrew the filter cap on the right behind that panel. check it's intact and clean iside, if not clean it out or replace it and that should fix it. be careful screwing the filter cap back in and make sure its on tight.
to check your pump is working you can pull out the machine and check that water is coming out of the hose by putting it on the pump out / drain cycle after pouring in some water for it to pump out.
Dec 08, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf541
ckd to be sure pump is operating in drain/spin feel pump housing for vibrationn from pump spining if pump not runing or huming ckd voltage to pump with wires removed.. voltage 110? pump probably bad ck for loose impeller they have been known to come loose from motor shaft..no voltage? ckd wiring at control bd last resort bad control bd..good luck
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Will not drain
probably the pump impellor is jammed. it behind the rear cover, disconnect the pump, its only small, and clean all the pipes. check the little impellor turns freely.
Feb 19, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint WD51P First Edition 1100
two possible cause. 1)drain pump motor faulty. 2)some thing struk inside the pump. it easy to locate the pump ,normally at the bottom near the draining pipe .hope it help
Aug 02, 2007 | Hotpoint WMA46 Front Load Washer
Error E15 - MAchine not draining
drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Nov 10, 2006 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
227 people viewed this question
Top Washing Machines Experts
