Question about Welding Tools
Lincoln MIG welder: Gas not shutting off.
Hi, I am looking at a used Lincoln MIG welder, I believe its a 175 or 180. The owner says it works fine in every way, however he says the gas keeps flowing and will not shut off. I am hesitant to buy the machine until I have an idea what's likely wrong. Could it just be a solenoid or stuck gas valve?
  • 850 Answers
Gas regulator needs checking or replacing!
Or you can use GASLESS WIRE!
Posted on Jul 24, 2009
Can the lincoln 305 d 1727-3 mig weld
If it has a setting for constant volatge, that is for wire feeders, flux cored or mig. Constant current is for stick welding. Some wire feeders have a switch to use them with a constant current machine, but that doesnt work very well, and , in my opinion, is hard on the computer in the feeder.
It looks like the ones we use in the field with a ln-25 wire feeder and flux cored wire. for mig you will also need a bottle of sheilding gas.
Jan 28, 2011 | Lincoln Electric Ranger 305D K1727-2...
Im looking into getting a mig and have come across the century (by lincoln) welders for 299. is this a quality welder and of same quality as a Lincoln brand.
No, it's not going to be equal to the Lincoln in all ways- but if Lincoln built it it'll be a decent machine.
In all honesty, if you can only have one welder it should be a stick welder. Mig welders are full of problems and, while ideally suited to 8 hour a day 7 days a week use, can be finicky as heck when used infrequently.
The stick welder allows you to work in all positions and all conditions, it's generally cheaper than Mig welding and it's usually faster.
lp
Jan 01, 2011 | Lincoln Electric LE 83180 Century...
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
The welder working its feeding the wire and gas but its not arcing
Check all wiring connections first, sounds like a broken / loose wire / terminal. If all checks out may be the transformer has failed. Also look for fuses.
If you have exceeded the "duty cycle" unit will shut down till it cools.
Jan 22, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Need an operating manual for the century 80
Do a web search for lincolnelectric.com and look for the manual for this model.
Oct 12, 2009 | Lincoln Electric LE 83180 Century...
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Owners manual for a century wire feed 83160 mig welder
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Apr 19, 2009 | Lincoln Electric LE 83180 Century...
I lost the owners manual to my lincoln weld pac#100 welder
hi mack:if you call or emal lincon customer care department theyll be happy to send you a owners manual to give you your gas shield capablitys ,thats what there there for.the customer. hope this helps jojogunne
Mar 10, 2009 | Lincoln Welding Tools
Welding Tools Logo
338 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
