Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge refrigerator not making ice but once a week I dont know why it worked great and then it stops then a week later its fine again???????????????????????????????????????????????
  • okcme2009 Jul 24, 2009
    thank you again my ac went out in my home and yes its been hot very hot I will give this a try again thank you
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
I think your re fridge is getting to hot it will only make ice if it can freeze it, if its not staying cold enough it will cease making ice, with the weather we have been having hot one week hotter the next rain and get cool well 89deg beats 109 your refridge may be struggling to keep its cool pardon the pun. I don't think there is anything wrong with it but it is hard on the pump when it gets that hot try putting a standard box fan blowing at the coils so that it helps move some of that hot air away from it this should help some.
best wishes okcfirewall
Posted on Jul 24, 2009
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
Water dispenser not working no water. ice stopped working a few weeks ago. fridge and freezer work fine otherwise.
If both stopped at the same time. Check the water control valve in the back of the refrigerator. Make sure the wires are connected and have not become loosen.
Jan 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE- GTS22WC refrigerator. Both the refrigerator and the freezer stopped cooling, We put it in the basement thinking it was no good, and after a few months we plugged it back in and it worked ok for about...
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Jun 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Freezer not cooling/making ice.
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
May 20, 2009 | GE PSS26PSS Stainless Steel Side by Side...
Temperature to warm
that is an automatic defrost problem
timer,heater or limit switch
Apr 22, 2009 | GE Profile PCF25PGW Side by Side...
Ice keeps building up on coils
We had the same problem with our GE frig, a Profile 24. When the tech came out, he explained that the energy efficient models have only 1 defrost heater, but the older units had 2 and the hook up and mounting positions were still there. As long as I directed him to install the 2nd heater he could do it. It turned out the original heater was just fine, so the replacement was installed in the 2nd heater space and it has worked fine for several years now. Before doing this on yours, I would verify that the defrost timer is working and the heater unit is ok.
Jan 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker problems
If the ice bucket is over filling there may be a problem with the ice maker as this should stop making ice when the bucket is full. The ice in the bucket can freeze together just due to the weight of ice cubes . I suggest you check the ice within the bucket is all broken up and not frozen into big lumps
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker No Longer Works - Water Works fine
Not sure if this will work for you - I had a similar problem with a Kenmore fridge. I removed the ice tray and found a piece of ice stuck where the ice is made and dropped into the tray. Once I clear this obstruction, the ice maker worked again. Also, check for the mechanism that indicates that the ice tray is full. This may be jammed or malfunctionin.
May 09, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
228 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
