Big Screen Projection receiver TV vertical pincushion problem
I have this old Mitsubishi VS-50VA2 Big Screen tv that i picked up today. The top and bottom sides have that pincushion effect, where it bends up in the middle of the screen on the bottom and vice versa on the top. Now, i took the shell off, but i dont know what to do. I was looking around the web, and it seems that a ''failing 'lytic cap'' may be the problem? also, the screen goes black randomly once in a while...ive got a lotta experience soldering and stuff, so if you can walk me thru it, i can do it. I just wish i had a service manual...thanks.
-Josh
  • Josh Hamman
    Josh Hamman Jul 24, 2009
    you mean the alignment? umm, is there not a way to do it myself? cuz its not worth paying to fix it...
  • Josh Hamman
    would something like this be what youre talking about?
    http://www.fixyourowntv.com/menumitsubis...
    Master:
  • 505 Answers
The aliment is out need a profession to adjust it for you
Posted on Jul 24, 2009
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Vertical picture problems on my 1993 mitsubishi vs-50va2
Can you provide a more detailed description of the vertical problem you are seeing? There are a number of defective parts that can cause different symptoms. Few vertical problems are adjustments. Most are either poor solder connections or defective parts. The parts cost should be minimal.
Please confirm you model number here and try to provide more details on the problem.
Thanks,
Dan
May 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Red and Blue convergence
you may need a new convergence board only a tv shop can tell you for sure
Nov 03, 2008 | Televison & Video
Mitsubishi VS-50va2 50 in. projection tv
You need go to set up andjustment mode and change the option of HOME THEATER to OFF position.
May 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
1992 mitsubishi vs-50va2
This symptom is typical of the infamous PIP module with the leaky
electrolytics. If the corrosion has not become so bad that the board is
unrepairable, you can change all of the surface mount caps and clean up the corrosion
Jan 26, 2008 | Mitsubishi VS-45605 50" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Convergence Problem?
Convergence problems are what you have possibly a pincushion error. Either way if you have to have a repair shop do the repair, you should look at replacing the old TV.
Jan 26, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
