Question about LG DLG2524 Gas Dryer
Front loading dryer
Check filter light is flashing. lint filter is clean. all lint has been vacuumed out of the lint filter cavity. still no luck
  • Anonymous Apr 20, 2008
    cleaned the lint off the screen but check filter light is still flashing.
Wrong Richard-sorry- but had this issue. Check filter light would come on and I ignored it (after checking for built up lint) and now the dryer wont start. I pulled everything apart and it seems I had a duct loose inside letting all the lint inside the dryer. It was a warning I ignored.
Posted on May 02, 2012
  • 2 more comments
  • Lorrie Schumacher
    Lorrie Schumacher Oct 09, 2012
    I opened the back of the dryer and looked inside. There was a hose that goes from where you check the lint trap and runs along to the outer area of the dryer-then you send it out your wall. The hose from the lint trap came loose and it was just blowing all the moisture and dust inside my dryer. I cleaned it all out. Reattached the hose. And let everything dry out for a day or so. It has worked perfectly since then and that was over 6 months ago.
  • Lorrie Schumacher
    Lorrie Schumacher Jun 22, 2014
    It's been almost two years since I did this to my dryer and it is still working perfectly!
  • Clarence washington
    Clarence washington Nov 16, 2014
    thank you! I'm going to try this in the morning
  • 489 Answers
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Posted on Apr 28, 2008
Flashing container light. what is this? Dryer
Try taking out the lint screen and scrubbing it well in the sink with hot water and a brush. If you havent cleaned out below the lint screen, get a vacuum and a crevice tool and remove any standing lint as well as cleaning the vent. Bosch lint screens clog easily especially if you are a big fabric softener user.
Nov 20, 2010 | Bosch Classixx WVF 2402 Front Load...
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
Lint filter light flashing...on off light flashing. Cleaned lint filter and checked vent. Vacumed and brushed out lint area. Will not turn on.
We had the same problem as many here have described. After cleaning out the vent system with compressed air and a vacuum cleaner, the appliance still failed to start. I unplugged the unit for a few minutes, turned it back on and it still failed to start. I turned the rotary dial to "SHORT" pressed start and it worked!!!! Not sure if thats the magic sequence or i just got lucky but Good luck.
May 15, 2010 | Bosch Nexxt WTMC 6500 Gas Dryer
After one load, dryer stopped working. lint
With the exhaust clear, you need to be sure that air is actually moving. It could be a bound or bad exhaust blower.
Mar 28, 2010 | Bosch WTMC3500UC Gas Dryer
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
Lg dlg2522w check filter flashing, motor spins,no
Did you put a load of wet clothes in the dryer and run it?
You can't change the setting while it's running.
The sensors won't let it heat up if there is nothing in the dryer.
This is not your grandmas dryer, this is a high tech machine.
There is probably nothing wrong with it.
Oh and the filter light flashes like that, it is supposed to, it is telling you to check the filter for lint.
Nov 24, 2009 | Zanussi FJD1666W Front Load Washer
Stops after a minute-dryer
blow lint out of motor best with compressed air don't bother with vacuum...waist of time
Aug 15, 2009 | General Electric WPDH8800J Front Load...
Lint filter not blocking lint
Make sure it isn't bent or has any holes in it and is sealing around the edges. If not, replace it .
Mar 19, 2009 | GE DCVH515EFWW Electric Dryer
Remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Jan 30, 2009 | Zanussi ZWF1440 Front Load Washer
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
LG DLG2524 Gas Dryer Logo
4,141 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
