Question about ASUS P4C800-E Deluxe Motherboard
P4C800E Deluxe Motherboard Problem
I upgraded to Bios version 1023 downloaded from Asus site.
After restarting it i set the time and date and saved them.
The motherboard powers up and i get a message them Bad checksum and then i restart it again, nothing shows up on the screen, the motherboard powers up but screen in blank, so i change the VGA card still nothing shows up, i have changed 4 VGA cards and still the same.
  • ASUS Master
  • 32,281 Answers
A bad checksum can be caused by a flat or near flat BIOS battery. Replace the battery and set the date and time.
Also set the BIOS to the default setup, ie go to reload default settings, or remove the BIOS battery for 1/2 hour the insert the battery and set the Date and Time.
Posted on Jul 24, 2009
I have a p4c800e motherboard when i close it down it loses time and date\r\neven when I put a new battery in why is this happening
It is possible that your CMOS battery is low or your BIOS is having problems already. You flash your BIOS and see if it works. It is very risky though it something goes wrong it will make your motherboard unusable.
Apr 30, 2011 | ASUS P4C800-E Deluxe Motherboard
I cannot install windows 7 on my p5vdc-mx motherboard, it keeps freezing on installation
Uodate the P5VDC-MX BIOS to version 0806. Download it from ASUS official site.
Aug 03, 2010 | ASUS P5VDC-MX Motherboard
Bios asus P5S800VM,rom
Try Updating your System Bios from
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5S800-VM
Version 1023
Update Procedure:-
1. Copy the ROM file in a pen drive
2.connect the Pen drive to the usb port of your Motherboard
3. Restart your m/c and press Del Key and Enter Setup
4. Go to
ASUS EZ Flash and update the Bios.
Jun 06, 2010 | ASUS P5S800-VM Motherboard
When i go to install OS, it shows that bios isn't acpi compliant
This errror coming from motherboard because your BIOS version is different as compare with new version, so download new BIOS for ASUS Intel 815E Chipset CUSL2-C from web site of ASUS there is detailed step of How to upgrade BIOS, you can upgrade BIOS by creating Bootble Disc otherwise you can Upgrade from OS.
I hope that this has been very helpful for you
Dec 12, 2009 | ASUS Intel 815E Chipset CUSL2-C...
When I make changes in bios they won't save. F10 doesn't work
If you are also experiencing a problem saving the date and time in the BIOS, then you probably need to replace the CMOS battery. Also, chech to see if the CLEAR CMOS jumper on the mobo is set in the correct position.
Oct 30, 2009 | ASUS P6T Deluxe V2, LGA1366, Triple...
Boot failure after upgrading bios asus p4xp-x
You have accidently corrupt mother board BIOS,you have to replace it ...no other choice...
Dec 10, 2008 | ASUS P4XP-X Motherboard
On board ethernet driver conflict with windows XP
go to the bios settings & there you can disable the onboard LAN ....
so by this you will be able to boot from your hard drive ....
you can go to the bios settings by pressing F2 (or delete key in some PC s ) at the time of the booting (before the OS loads)...
there in bios settings just search for the LAN device & disable it ...
that s all your problem will be solved ....
any doubts reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Jul 05, 2008 | ASUS P4C800-E Deluxe Motherboard
Intel cpu ucode loading eroor
You can upgrade your bios, you just need to visit the motherboard manufacturer site where you can download the latest bios.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=1276&modelmenu=1
You can also try to reset the bios first, you can reset it to default settings and if that will not work then you can upgrade the bios.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
and you can also check this site regarding bios upgrade
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Mar 21, 2008 | ASUS P5PE-VM Motherboard
A8N32-SLI Deluxe - Can not Load 'ASUS UPDATE' fro CD
It's not you. Asus's program from the CD doesn't function as you might except. You'll need to download, ASUS Update V7.06.02 Install Program for Windows 2000/XP/2003 & 64bit Windows XP/2003 within Bios Utilities. And flash your Bios from a floppy. Than download the Bios version you want. Having trouble getting the file to unzip? Download again but this time choose a different site. Like (Global) instead.
Luck!
please vote...
Feb 18, 2008 | AMD ASUS A8N32-SLI Deluxe Socket 939...
ASUS P4C800-E Deluxe Motherboard Logo
204 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
