Question about Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna
Touch screen dont work
When the phone is on i cant use any buttons nor the touch screen so i have to take the battery out to turn it off the the on button works but when its on nuthing woks. when i recieve a call then the buttons work but not the screen
Stuck on reset screen
Yes all u have to do is take the plug out take the battery & back out then
reset the phone u should be fine
May 23, 2014 | ZTE Warp
My touch screen won't work. The phone is not locked and the buttons work, but not the touch screen. Help!
Try to turn off the cellphone, remove the battery for 5 minutes then re-insert the battery and try again. If the touch screen still doesn't functions try to restore the factory settings.
Nov 19, 2010 | LG VX8575 Cell Phone
The touch screen does not work. I can see the background picture but it doesn't recognize any touch command. It won"t turn off either. If I click the lock button It turns black then turns itself on again.
My phone suffered the same symptoms, i was able to fix it by turning it off and on, waiting for the verizon word to animate, plugging it into a wall charger and I was then able to use the slider bar to unlock my phone, I was unable to select anything else on the phone so i closed it and used the qwerty keyboard to get to my touch settings menu, where i selected calibrate and followed the steps it told me to in order to calibrate my phone, I had to repeat the whole process several times before my phone was back to 100% hopes this helps.
Jul 03, 2010 | LG enV VX9900 Cellular Phone
My HTC Diamond Touch Screen wont work
you can try to recalibrate the touch screen to see if that works,
Start> settings> display> calibrate
* since screen is not working you will have to go the long away and use buttons on phone and nav wheel to get to these options
Jun 17, 2009 | HTC Touch Diamond Smartphone
My iphone touch screen dont work
sync it with itunes on you're computer
Mar 01, 2009 | Apple iPhone Smartphone
End call button doesnt work--need help!!
u have to replace the carbon pad in phone
Feb 13, 2009 | LG Vu CU920 Cellular Phone
My sgh-f480 touch screen wouldnt just respond.how do i fix it?
It's relatively simple, I did this way: (my phone has the call off and photo buttons that don't work..and had had the touchscreen apparently broken) I tried to completely disassemble the phone and when I reassembled it, the touchscreen worked perfectly.. But the buttons doesn't work...
Feb 06, 2009 | Cell Phones
Touch screen not working
the only solution i have found...replace the phone
Feb 20, 2008 | HTC Touch P3450 Smartphone
Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna Logo
162 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
