Question about MySpace Computers & Internet
My pop out player on my space doesnt work.and there is no sound coming out of my speakers if i visit like you tube and stuff...what is the problem?
    Problem Solver:
  • 7 Answers
Have you tried looking at the sound stats on the Control panel? If you go to Start / Settings / Control Panel - then select the speaker icon. Check the first bar 'Volume Control' is at the correct level and hasn't been muted.
If this is not working you may want to try the microsoft office or other relevant website.
Hope this helped.
Danger :)
Posted on Jul 27, 2009
Volvo 2000 s 80 Radio/CD player screen lights up, but nothing comes out of speakers. Occasionally, I will here a speaker pop. How 2 diagnose? Water on floor. Possible damaged amp?
doesnt sound good ..water there
could be bad earths
amp may have a fuse
speakers need to be tested manually
these links may have wiring layouts etc
VOLVO Car Radio Stereo
Audio Wiring Diagram Autoradio connector wire...
Volvo Radio Wiring Diagram
Oct 11, 2016 | 2000 Volvo S80
Jukebox problems
Simple stuff....
Speaker wires disconnected
Speaker wires shorted
Volume turned down or muted
More complex stuff...
Speakers blown
Amplifier output transistors fried
Sep 03, 2014 | Audio Players & Recorders
No sound coming from my speakers
Possible scenerio's with the little info you gave.
1.You have a bad speaker thats blown or the wires are touching the chassis of your car.
2. You have a factory amp and you need to connect the blue wire to the amp turn on wire. And if it still doesnt work then you have to rewire it complete or maybe have to get a special car amplifier compatible harness so your aftermarket works with your amplified system in your car.
3. In certain Ford cars they crisscrossed the back speaker wires. To test this unplug your harness from the radio. VERY IMPORTANT( splice these colors of wires in the middle enough so you can use a 9volt small rectangular battery to make the speakers you want to test pop(harmless))
1. green = back left + speaker
2. green/black = back left - speaker
3. purple = back right + speaker
4. purple/black = back right - speaker
test green speaker wires first touch battery to the + and - and the speaker should pop if not you have already discovered the problem. Know this time pop the green + and the purple/black - on the 9volt battery if the speakers pop you have found the solution.
Just criss cross the the negatives of the back speakers. From the radio harness end attach green to green, purple to purple, green/black to purple/black and last purple/black to green/black. And all your speakers should work again.
Dont ask me why late Ford Models crisscrossed their speaker wires. They just did.
Apr 08, 2010 | JVC KD-G140 Car CD Player
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
One speaker making a popping sound
try switching the popping speaker to the other side and see if it still pops if it does then you have probably damaged the driver in the speaker if it doesnt pop then the problem probably is in the receiver
May 27, 2009 | Samsung Audio Players & Recorders
No sound form my magnavox mrd-200
As long as the colored connections are in the correct holes (red with red and so on) then you should have sound if not then the built in amplifier is shot, it is probably better if you get a new system or contact Magnavox for a exchange price on out of warranty units which they have
Aug 16, 2008 | Philips 0603 magnavox mrd200 System
I have a philips cd player model# FW-C70/37, that has power going to it but has no sound coming from any of the speakers, nor will the cd changer open.
cd players work without use of volume controls coax cables hook up's and then by setting reciever to proper button so sound can come out
you might have had a power surge that fried your system but lets look at easy stuff first
fuses
lines in properly and connected
test on an old sterio with speaker hook ups and test your speakers by plugging in to old beat box
make sure wires are not scorched
turn on receiver fm see if speakers work change channels to sterio and mono settings if speakers start to work on sterio or mono setting chances are power surge blew out your system
hope this worked
May 07, 2008 | Audio Players & Recorders
Popping sound and picture goes out
Sounds like the flyback or the picture tube. Either items can cause this. If the pop comes from the rear right side its the flyback. If the sound comes from the lower front behind the speaker grille its the tube. Let me know what you discover as I have access to any of the parts you would need.
Mar 10, 2008 | Philips 60P8342 60" Rear Projection...
Won't work
Um, that sounds like a sound card drivers problem more than the speakers theirselves. Can you try connecting any other source of audio to the speakers, like a Mp3 player, a walkman, a diskman ? Those portable players have the same audio output connections than a PC's standard sound card, a 1/8 mini stereo plug. If it works fine this way, it's a sound card drivers issue. Now if it's so, what i'd suggest you to do, is to check which sound card you got, and to reinstall or update the drivers for the device. I can help you with that part too, keep me posted on the status. Thanks, cheebster :)
Jun 23, 2007 | Logitech R-10 Computer Speakers
Computers & Internet Logo
165 people viewed this question
Top MySpace Computers & Internet Experts
Nicholas Bannister
Zachary Reed
Tom Del
Level 1 Expert
Are you a MySpace Computer and Internet Expert? Answer questions, earn points and help others
