Question about Nokia N70 Cellular Phone
MEMORY CARD CANNOT SAVE ANY DATA - Nokia N70 Cellular Phone
  • spx09 May 11, 2010
    did the memory card work before in your device?
    did you make sure that your phone supports that size of memory card?
3 Suggested Answers
anandg27
  • 1272 Answers
SOURCE: problem in my nokia n72 memory card
There is a lil bit of tweak that you will have to do.
goto messaging and then goto settings here select the message memory to be saved in memory card.
Once you have some data transfered thru bluetooth, it will go to memory card.
Rate it, if it helps.
Posted on Jun 24, 2009
  • 9 Answers
SOURCE: phone memory full delete data.i have a 2gb memory card
thats not a big problem just get ur mobile scanned along with ur memory card and if the problem presist then get ur mobile software re installed from nokia service center they will first format the phone and then they will re install it .it might be possible that ur mem card is corrupted so get that checked .but generally it happens because og virus
Posted on Sep 07, 2009
Hi i loackd my memory card few mnths ago and nw i forgot the password i tried diffrnt paswrds but its stil locked,,,n it gvs option of formating it but i dont want to loose my images vdos n muzik...kindly...
Memory card in a locked condition, the data can be saved. There are two ways you can do:
1. Use the data recovery software (must be software full version). How: insert memory card, run the data recovery process, select the drive memory card, etc. Save the file to your hard drive recovery. After the data saved, memory card format (quick format), then restore the data into the memory card.
2. Quick format memory card, and do the data recovery process. So that data can be saved, do not do a full format, but do a quick format. Tools such as hard drives, flash drives, memory cards, when done quick format, data can be saved.
Sep 24, 2011 | SanDisk 2GB microSD Memory Card
Memory card not formatted followed by operation failed is displayed when i try t open the memory card of my phone,,,,,,what can be done to recover data from it?????
Memorycard usually get corrupted while transfering data from devices like digitalcamera, mobile phone and computer. However, you can recover data from memory card with memory cardrecovery software.TenorshareData Recovery is a powerful data recovery program that can recover lost,formatted, corrupted, misplaced or accidently deleted pictures, videos, music,etc. from memory card, memory stick, SD card, CF Card and so on. You candownload it and scan your memory card for free to preview whether your datacan be recovered. Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
Sep 17, 2011 | Nokia 6303 Cell Phone
I bought a new ps2 and a datel 32mb card and the game i put in says there is no memory card,
Try these steps. If this doesn't work you may want to take the card to Game Stop or something and have them test it to see if it's working. Hope this helps!
  1. Insert the Memory Card into the PlayStation 2 console. The port is located directly above the controller port. Note that there are two different memory card ports; there is no difference between the two. Some games, however, will attempt to auto-load from slot one so it is recommended that you keep your memory card inserted in slot one.
  2. Plug your controller into the PlayStation 2. Power up the system without a PS2 disc inserted. You will be taken to the system menu screen. Select the "Memory Card" menu to examine any data on the card. If the memory card is new there should be no data on the card, if it is used you may see old saves from the previous owner on the card. If you no longer desire to keep these saves, you may highlight them and press the "Triangle" button to delete them.
  3. Insert your PlayStation 2 game disc into the system. When the disc appears on the system menu, select it. Load the game, and play until you are prompted to either create a user profile, or to save your game. Once you have saved any data to the memory card, reset the system.
  4. Select the "Memory Card" menu and examine your memory card. You should see a new icon representing your game's save data. If this data appears on the card, you have correctly set-up your PS2 Memory Card.
    If the data does not appear on the card, you will need to format the card. If the system detects corrupt data on the card it will automatically open a prompt asking if you would like to format the memory card. Select "Yes" and the PlayStation 2 will format the card.
Dec 31, 2010 | Datel Max Memory 32MB Memory Card
I cant format my card iwill format my card then all song and picture wiil com back in card
Hi
Please follow these steps to format your memory card
1. If you format your card then the data will be erased.
2. If you want that data after formatting, you can get it by doing like this.
3. Go to http://www.recovermemorycards.com/ and download and install the software.
4. Then recover the data from the memory card using this software.
Jul 29, 2010 | SanDisk 1GB Memory Stick M2 Memory Card
How to save info to memory card on samsung d900i? Many thanks
Unfortunately there is no option to directly save data to the Memory card if the data is transferred using Bluetooth. you need to manually transfer data after saving it to the phone memory.
If it is through Data Cable then you can save the data directly on the memory card.
Nov 23, 2009 | Samsung SGH-D900 Cellular Phone
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Memory card
it could be a glitch in the memory card, because a similar problem happen with my gamecube memory card and when i save data on it, it won't keep the data so i don't use it anymore. so a solution could be to buy 2 new memory cards and save the same data on both so if one has the same problem, you have backup data. if that solution does not work it could be the games or the console.
Apr 26, 2008 | Sony PlayStation 2 (PS2) Console
Nokia N70 Cellular Phone Logo
88 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
