Question about Dell Inspiron 1501 Notebook
Laptop won't turn on.
My laptop won't turn on. There is no indication that the power cord is connected. I have tried several outlets... No luck! I tried holding the power button down for 30 seconds... No luck! Its like there is no life left in my computer! I need help!
  • 52 Answers
Check your power adapter. If its really hot or making a buzz noise most likely it has failed. And you can find new ones dirt cheap on ebay.
Posted on Jul 26, 2009
  • 202 Answers
Check your power adapter, it may have failed. try it with the battery removed incase the battery has shorted cells.
Posted on Jul 24, 2009
My dell studio1555 laptop is not recognising my mains lead/charger
Plug the adapter into the wall outlet or power strip. If using a power strip, make sure the strip is on. Most laptop power adapters have a small LED light; the light will illuminate when power is being transferred from the outlet to the adapter. If the light illuminates, chances are you have sufficient power to supply your laptop. Wiggle the power cord if the LED light did not initially illuminate. If the light turns on and off when you wiggle it, you might have a loose cord in the adapter, or the outlet could be faulty. Plug the adapter into another power outlet, preferably a different circuit in another room, if the LED light did not illuminate the first time. If it lights up from the second outlet, the first outlet either does not work or other devices were using too much power on the initial circuit. Connect the other end of the adapter to the laptop and turn the laptop on. When the computer starts up, you should see an indication of how the laptop is being powered in the lower right-hand corner. If you see a battery icon, then the laptop is being powered by the battery, not the adapter. Make sure both ends of the adapter are securely connected. If they are, and if the LED light on the adapter is lit, then you likely have a faulty wire that is not properly connecting to your computer. If you see a plug or adapter icon, then the laptop is successfully being powered by the adapter. If the LED light on the adapter is not lit, then the bulb is out, but the adapter is still working.
Jan 20, 2013 | Dell Computers & Internet
Tip
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
My toshiba is charging but onlythe cord out lets bliking what does that mean
Jan 20, 2013 | Toshiba Satellite Pro L300 Notebook
My laptop won't turn on. I tried taking out the battery, a different battery, a differnet power cord. It won't turn on. Is there a way to reset it?
Are there any lights or indications on the battery itself that might tell you if the battery is good? I had a laptop with a similar problem and it turned out to be both a bad battery and a bad "power brick". replacing both fixed my issues. Also, try holding the power cable at the point where it connects to the laptop and push to the left or right. A friend's laptop would only start if you held the power cable to the left. Otherwise, it sounds like a mother board issue. Sorry.
Oct 11, 2012 | Dell Inspiron 8600 Notebook
Gets no power from wall or battery
Few things in life are as frustrating and infuriating as working ******* your laptop, only to see the screen go dark due to a sudden power loss. While there's a good chance your hard work and data is gone, the more concerning issue involves the cause of the sudden loss of laptop power. A suddenly dead laptop could indicate a more serious problem, or simply be due to a loose battery or power cord.
Overheating
If your laptop's fan was running hard and fast right before your laptop went dead, it's possible the machine shut itself down to avoid damage from overheating. The internal electronic components of a laptop generate heat when the computer is turned on, and this heat must vent to avoid causing damage to the machine. If the air vents are clogged or blocked and the heat inside cannot dissipate, the laptop will power down without warning to prevent possible damage. To avoid this problem, ensure that your laptop's fans and air vents are clean and clear, or use a laptop cooling stand to help vent the heat.
Battery Issues
Laptop batteries are not exempt from malfunctions, and a sudden power loss may point to a problematic battery. A loose connection may cause a surprise laptop death, as can dirty connectors. Like most other battery types, laptop batteries are not immortal and eventually lose the ability to hold a charge for long. Some laptops have sensors and circuitry to monitor the battery, and will cut power to and from it should it become too hot or exhibit too high a current. Try cleaning the connectors and reseating the battery properly to fix the problem. In the event of a loose connection, a repair technician may be your best course. For malfunctioning batteries, a new replacement battery may be the best way to prevent future power failures.
Electrical Problems
If you were using your AC adapter for power right before your laptop powered off, there may be an electrical problem somewhere along the line. The outlet you were plugged into may have short circuited, or the adapter itself may have overloaded. The connector on the back of your laptop may be loose, preventing proper connection of the adapter. A short circuit within the laptop itself may have occurred, preventing either the battery or adapter from providing power to the rest of the electronics. Work backwards to find the source of the power supply problem. Try a different electronic device in the outlet, and insert the adapter itself into a different outlet. Reinsert the various cord ends into the adapter and laptop to ensure a tight connection. If a short circuit seems the likely cause, seek the help of a professional technician for repair.
Troubleshooting
Try to ascertain what occurred right before the power loss. A physical move of the laptop may have loosened the battery or jostled the adapter cord loose. Try removing and then reseating the battery and tightening the adapter cord. A loud fan noise may indicate that the machine was on the verge of overheating. Let the machine cool completely before attempting to reboot. An unusual noise emanating from within your laptop may indicate a short circuit. A beverage spill can cause the death of an laptop if not attended to quickly, causing short circuits and power failure.
Precautions
Observe standard safety procedures when dealing with electricity, and never disassemble or examine an outlet or your laptop without disconnecting all power first. If delving into your laptop to check for short circuits and loose connections, work in a clean, open area to avoid introducing any new contaminants to your laptop's vulnerable interior.
Read more: My Laptop Suddenly Has No Power ' eHow.com http://www.ehow.com/info_10023896_laptop-suddenly-power.html#ixzz1XFwtBENN
Sep 07, 2011 | Computers & Internet
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
-Anonymity
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
Hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Compaq nc4200 Notebook
The computer has completely blacked out, i have tried plugging it in several different outlets and it will not turn on. what do i do?
The issue can be with the power cord which give connection to your laptop, try borrowing the cord from someone using similar laptop if the result is same you need to get it checked at the service center
In a laptop we cannot do nothing much on our own as we loose the warrenty while opening it on our own.
Regards
Vikram
Nov 29, 2009 | Computers & Internet
Battery will not charge on a dell d610 when plugged into outlet
I have seen this with faulty batteries.
Try changing the battery.
Also, check in the BIOS that the adapter you are using is recognised and shows a state of charging with the battery in.
Apr 01, 2009 | Dell (F2273) Motherboard
Dell Inspiron 1501 Notebook Logo
112 people viewed this question
Alun Cox
