Lint from my washer keeps clogging up my drains!
It does not appear to have a lint filter built in. Anyone know this problem?
  • seagazer101_ Jul 26, 2009
    Thanks for the assistance, but the problem is not lint on the clothes or anywhere in the washer. It is in the sink it drains into; it seems to put out about five times as much lint as I've ever seen, and I've twice had my drains snaked out because of lint clogs.
    President:
  • 3,085 Answers
There are mesh screen lint traps that attach to the end of the drain hose.
Check Home Depot or Lowe's.
Posted on Aug 24, 2009
    President:
  • 1,776 Answers
There are a couple of things that you could try; the first potential cause is a slow drain problem. To test, fill the washer to the maximum level, then turn the timer to spin and time 90 seconds. If the water isn't completely pumped out, you have some blockage in the drain. The water drains slow and leaves lint on the clothes.
The second thing that you can check that may cause lint is water pressure, especially cold, since that is what is used for the rinse. Check the screens at the water inlet valve and make sure they are clean and open.
Sure hope this helps and best wishes.
Posted on Jul 24, 2009
Trum turns but will heat dyer. Is there an internal lint filter?
bottom lower right remove panel drain if ok then lint filter inside top or lint in vent
Nov 13, 2014 | Splendide 2000S Vented Washer/Dryer
Where is the lint filter on Speed Queen...
You didn't say if it was top or front loading and did not include a model number. The model number is usually on a tag that is covered by the lid or door.
As far as I know most washers do not filter out lint during the wash but rely on the lint being suspended in the wash water and expelled with the dirty and rinse waters. Many do have filters in the drain that do need to be cleaned at times but the symptom is usuall a slow drain or not draining.
How to Avoid Lint on Clothes from Your Washing Machine Top Load Washer...
This is an active lint filter machine.
Filter Flo Lint Capture
At this link you can download Speed Queen Product Manuals.
Maintenance Tips
Front Load Washer Troubleshooting Lint
Oct 16, 2014 | Dryers
Washer doesn't spin or drain
Clean your INLET and OUTLET filters, remove the inlet valve and check flow, also check the drain pump for clogging or lint collection.
Click this link: Lint filter
Jan 21, 2013 | Washing Machines
My HE2 washer will not continue on to the drain and spin cycle.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 16, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Sears Kenmore washer, model # 110.28922791. I bought it approximately 10 years, give or take a year or two. I know it does not have a lint filter but is there any way to clean whatever processes...
HI- Washer really don't have a lint filter so to speak. Some of the front load washers have a filter in the drain pump but that basically just keep the quarters and bobby pins from ruining the pump. Is it possible to have someone extend your standpipe with a larger diameter pipe that you could place a screen into, or place the screen on the drain hose and then put them both into the larger pipe. A plumber should be able to figure something out. It would be about $1000 dollars cheaper than buying a front-loader and probably more effective. Good luck.
Sep 24, 2010 | Washing Machines
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Nov 01, 2008 | Washing Machines
Won't drain...
on the pump there is a lint filter it is either in the drain hose coming from the tub or there is a slot on the pump that screws off.you have to take the front lower panel off to get to the pump after you take the junk out unplug washer for 60 seconds to reset computer. let me know what you find
Jan 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
My washer/dryer is not draining properly.
If the pump is not draining, either the drain filter screen is clogged with debris, the drain pump is jammed by foreign debris or the drain pump itself has failed.  More than likely something is clogged in the filter screen or a sock is jammed up inside the drain bellows tube just before the filter.  Pull the drain filter screen out and look up the hole to see if there is any material stuck inside.  Usually that's the problem.
Nov 19, 2007 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
