There is a fuel shut off switch I think?not shure were button can take a guess passenger kick panel under dash or in trunk near the wire harness that feeds the tank.maybe a relay on the fire wall passenger side engine compartment. 1more thing it could be vapor lock in the hose take it off in the engine area get small glass have some one crank it over until late gas floss out reattach it and go .
If it cranks good but won't start, have a helper crank it while you check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure, also, check fuel injector pulse. Any applicable trouble codes?
I need more info, have you done any testing?
Testimonial: "thanks an yes its firing an if i spray starting fluid it will run but wont stay running"
You need to check fuel pressure and fuel injector pulse.
is it possible i got a bad pump
W/o checking fuel pressure, I don't know? When you first turn on the key, no crank, can you hear the fuel pump run for a couple of secondshttps://s29.postimg.org/u3smc6ldz/fuel_t...
Click on the link, the top wire on the right is voltage for fuel pump motor, the bottom wire is ground. Check voltage and ground with engine cranking.
