Question about HP LaserJet 1022 Printer
Unable to Connect the Printer Access Denied
I got the error '' Unable to connect the printer , access denied , printer could not be started'' . I have a XP home m/c to which i have connected HP 1022 printer. I have shared it with all machines in the LAN. On the host m/c printer working fine. but from the workgroup pc it shows ''Unable to connect''.
Then i have to restart the host PC everytime, Then it works fine for max half an hour. repeat the issue. and same process again.
Any smart answer will definitely help me out. Pls Help me?
  • 2 more comments
  • bajarang_wab Jul 24, 2009
    Dear pslamb1962
    I connect hp 1020 Printer One Computer Share Printer on another computer but when i restart computer that is client computer it show unable to connect or access denied but when i go to start- run-and type \\computername and click on ok buttion printer working
    fine pl help me
    Bajarang Wable
  • pslamb1962 May 11, 2010
    Hi bajarang_wab did you get this resolved? sorry been on holidays and away from pc. If not, your saying that it does not matter which pc you use as the host, none of the other pc's can get to it via the network... what type of router are you using?
  • aa1Consult May 11, 2010
    sounds like a permissions issue and since XP home isn't a network OS, it may be limited to what it can do in that reagrd. I would move the printer to a PC running XP Pro or any other NOS
    Sounds like the host machine is loosing that configuration. Have you tried making one of the other machines the host?
2 Suggested Answers
  • 7 Answers
SOURCE: i got the error '' Unable to connect the printer
Are you on the same network as the host machine. In simple terms, the machine that you are trying to printer should be on the same network/domain.
click on start, right click on my computer and go to properties. Under properties check the computer name tab. specifically the workgroup. see if that matches the host machine. If it's different that's the issue.
If its different click on the button change, and type the domain in the box below.
hope this helps.
Posted on Feb 17, 2009
I share hp laserjet 1020 printer but when i shut down after start pc printer not access & unable to connect or access denied display occured on other pcs, what i do?
When you share the printer that is connected to your computer for other computers to use this printer, your computer MUST be left on at all times for the other computers to print to this printer.
The reason is, your computer acts as a print server, it collects the print data from the other computers and sends it to the printer.
Jul 10, 2011 | HP LaserJet 1020 Printer
Tip
Network Connection Always Shows Access Denied
If you are always getting Access Denied errors when trying to connect to a XP computer,
and you know you have the correct user names and passwords on the computer,
the solution may be a simple registry edit.
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE / SYSTEM / CurrentControlSet / Control / Lsa
  3. Change the value of a key called "restrictanonymous" to 0 instead of 1
  4. Don't change "restrictanonymoussam" value.
  5. Reboot
on Sep 20, 2010 | Computers & Internet
I get a access denied error when i try to transfer programs to my ti 84 plus
Here is what the TI Knowledge Base has to say about resolving the problem you have.Hope it helps.
How do I resolve the error "Access Denied" when transferring an App or OS using the TI Connect software?
The error "Access Denied" indicates that the TI-Connect software could not complete the current transfer due to an unforeseen error. Please try the following troubleshooting steps if the error persists.
Perform a manual "Garbage Collect" on the calculator (TI-83 Plus and TI-84 Plus family only):
• Press [2nd] [0] [TAN] [ENTER] [ENTER] [2].
NOTE: A manual "Garbage Collect" can take up to 5 minutes to complete.
• Attempt to transfer data to the calculator.
Uninstall and reinstall the TI-Connect software:
• Go to Start >> Settings >> Control Panel or Start >> Control Panel and select "Add or Remove Programs".
• Locate the TI-Connect software in the list and then choose "Remove".
• Once the software uninstall process has completed, please shut down and power off the computer.
• Wait approximately 20-30 seconds and then reboot into Windows.
• Download and install the latest version of the TI Connect software from the TI Connect Software home page.
• Once the TI Connect software install process has completed, restart the computer before using TI-Connect.
If the above troubleshooting steps do not work, please contact TI-Cares Technical Support for additional troubleshooting.
Oct 28, 2009 | Texas Instruments TI-84 Plus Calculator
I got the error '' Unable to connect the printer , access denied , printer could not be started'' . I have a XP home m/c to which i have connected HP 1022 printer. I have shared it with all machines in the...
hope this helps.
Feb 17, 2009 | HP LaserJet 1022 Printer
SQL Server does not exist or access denied
check your firewall or the sql server machine firewall.
Jan 06, 2009 | Microsoft SQL Server 2005 Standard Edition
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
Unable to share printer
You need to go into the machine that manages the printer and allow the access denied machine access or to share printer. You may have to run the network setup wizard in order for the machines to recognize each other.
Jun 23, 2008 | Dell Inspiron 1501 Notebook
Access Denied
This is a software issue. Sounds like it needs to be reinstalled but someone with password access.
Jan 23, 2008 | HP LaserJet 6L Printer
Access Denied
Just see are you login as Administrator or try to install manually with driver which is digitally signed!
Jan 23, 2008 | Office Equipment & Supplies
HP LaserJet 1022 Printer Logo
780 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
