Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
My tv is all mad cow
I think there is a problem with the convergence thing but i try to use the manual reset and i cant allign all the boxes.
  • 203 Answers
If your convergance amps are dying, nothing you do in the manual converge menu is going to work. And in fact, it can actually lead to more issues...
Posted on Nov 21, 2007
Got new STK392-040 chips and picture is still distorted. Manual convergence still won't alligne all colors.
the 183 is entry into the tech menu===you need to test all the low value resistors around the convergence chips(only 6 or 8) and they will read low and a resistor with NO reading may be your problem.
Also these sets use a pico fuse going to each chip--either right with it or back at the source----know what a pico fuse looks like"
Mar 12, 2012 | Samsung HCM4216W 42" Rear Projection...
50FX20B- I am trying to allign the digital array and cant get the red to move,how do I move it? (the blue WILL move)
Please replace convergence output chips in tv to solve the problem. It requires good soldering skills/ expertise and click to buy convergence repair kit for this tv that has all required parts and instructions.
Hope this will help.
Thanks.
Jun 11, 2011 | Hitachi 50FX20B 50" Rear Projection...
The colors are unalligned and the picture is blurry
hello,,the deffective part of your tv probably the convergience ic,it is a 2 pcs big ic with heatsink mounted on the mainboard you can replace it with a new one..or try to adjust first the allignment of your cathodes the RGB cathodes..on your front pannel there is a convergeance manual allignment button use this button to allign the convergeance..on your remote control there is also an allignment command consult your manual for the command .after the adjustment you must save the adjustments before exit the convergeance adjust..if thris adjustment do not work replace the convergeance ic ..mostly the ic is labeled STK XXXX..
GOODLUCK i hope i this helps you..
please rate my help tnx.
May 29, 2010 | Philips 51PW9303 51" Rear Projection...
My hitachi tv's picture is distorted red and green like a 3-d pic
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 08, 2010 | Hitachi 57F710 TV
Convergance wont allign on 50" panasonic
Must replaced the 2 convergence ICS,and all it resistors.Must know how to solders.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts,and lobors.
Jan 16, 2010 | Philips 46PP9302 46" Rear Projection...
I have a convergence problem on my Mitsubishi VS-55601
ICS with some resisters,tries these websites Tv rpair Word.com or Tv repair kits.
Nov 02, 2009 | Mitsubishi VS-55601 55" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Red and white allignment
you need new convergence Ics. This is a easy repair. let me know your model number of your TV and I will post the Convergence ICs numbers and also post a link where you can get new Ics that come with free installation instructions with pictures and free on line tech support.
Apr 23, 2008 | Televison & Video
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
